gettext 0.19
gettext 0.19 Partha Bagchi 16 May 11:02
  gettext 0.19 Marco Ciampa 16 May 12:32
   gettext 0.19 Michael Schumacher 16 May 13:10
Partha Bagchi
2014-05-16 11:02:04 UTC (almost 11 years ago)
gettext 0.19
The latest gimp git pull warns that I require gettext 0.19 or higher or the build will have a partially broken localization. However, the latest available gettext from GNU is 0.18.3.2.
Why this requirement for a version higher than currently available?
Thanks, Partha
Marco Ciampa
2014-05-16 12:32:55 UTC (almost 11 years ago)
gettext 0.19
Because current gettext is throwing away translated strings off gimp script-fu scheme plugins.
Newer gettext is already (and will be when published) corrected.
If you are able (I currently have some problem in compiling it out of it's git dev repo) you can download current dev gettext and use it.
bye
Marco Ciampa
"L'utopia sta all'orizzonte. Mi avvicino  di due passi, lei si allontana
di due  passi. Faccio dieci  passi e  l'orizzonte si allontana  di dieci
passi.  Per quanto cammini, non la raggiunger  mai. A cosa serve
l'utopia? A questo: serve a camminare."              Eduardo Galeano
| Linux User  #78271 |
| FSFE fellow   #364 |
2014-05-16 13:10:32 UTC (almost 11 years ago)
gettext 0.19
Von: "Marco Ciampa"
See https://bugzilla.gnome.org/show_bug.cgi?id=720052
