harfbuzz
harfbuzz Thorsten Stettin 03 May 15:18
  harfbuzz Mukund Sivaraman 03 May 15:43
   harfbuzz Thorsten Stettin 03 May 15:54
   harfbuzz Thorsten Stettin 03 May 16:37
Thorsten Stettin
2014-05-03 15:18:54 UTC (almost 11 years ago)
harfbuzz
yesterday I built gimp-2.9.1 packages for ubuntu with the recent sources. I couldn't built for saucy. The reason is the harzbuzz version 0.9.19 is too old. There was no problems with trusty since the version ships with trusty is 0.9.27. So far so good.
My first idea was to build new harfbuzz packages - 0.9.27 - for saucy in my gimp-edge PPA. I could built it but an upgrade fails due to dependency issues.
Regards
Thorsten
Lao-Tse sagt: Nichtstun ist besser, als mit viel Mhe nichts zu schaffen.
Und er sagt auch: Ich habe drei Schtze, die ich hte und hege. Der eine ist die Liebe, der zweite ist die Gengsamkeit, der dritte ist die Demut. Nur der Liebende ist mutig, nur der Gengsame ist grozgig, nur der Demtige ist fhig zu herrschen.
Mukund Sivaraman
2014-05-03 15:43:59 UTC (almost 11 years ago)
harfbuzz
Hi Thorsten
I have lowered it further now to 0.9.19 (it seems to be API compatible). Please can compile and check?
Mukund
Thorsten Stettin
2014-05-03 15:54:28 UTC (almost 11 years ago)
harfbuzz
Am 03.05.2014 17:43, schrieb Mukund Sivaraman:
Hi Thorsten
Mukund
Hi Mukund,
I patched the configure.ac for now. I could made a successful build. Ok, I pull the changes and will build again. Thanks for your work.
On monday I will check if there are runtime issues. My local machine runs Trusty.
See you
Thorsten
Thorsten Stettin
2014-05-03 16:37:22 UTC (almost 11 years ago)
harfbuzz
Hi Thorsten
Mukund
It works: https://launchpad.net/~otto-kesselgulasch/+archive/gimp-edge
