GIMP and Adobe RGB (1998)
| GIMP and Adobe RGB (1998) | Elle Stone | 17 Apr 11:08 |
| GIMP and Adobe RGB (1998) | Øyvind Kolås | 17 Apr 14:02 |
| GIMP and Adobe RGB (1998) | Nicolas Robidoux | 17 Apr 14:48 |
| GIMP and Adobe RGB (1998) | Gez | 17 Apr 16:10 |
| GIMP and Adobe RGB (1998) | Elle Stone | 17 Apr 15:19 |
| GIMP and Adobe RGB (1998) | Gez | 17 Apr 15:31 |
| GIMP and Adobe RGB (1998) | Nicolas Robidoux | 17 Apr 15:49 |
| GIMP and Adobe RGB (1998) | Øyvind Kolås | 17 Apr 16:39 |
The other day there was an IRC discussion of the possibility of GIMP supporting RGB color spaces other than unbounded mode sRGB.
I was surprised to see in the transcript a statement that GIMP shouldn't support Adobe RGB (1998).
The rejection of Adobe RGB (1998) seemed to be based on the premise that the accidental nature of the creation of the Adobe RGB (1998) color space means that the Adobe RGB (1998) color space is somehow not useful for image editing.
Back in 1998 Adobe intended to create an entirely different color space (https://en.wikipedia.org/wiki/Adobergb). Instead Adobe accidentally released a color space with the same red and blue chromaticities as sRGB, but with a more saturated green chromaticity.
Adobe tried to fix what they saw as their mistake. But photographers said, "No, we like the extra color gamut. Adobe RGB (1998) holds more of the printable greens, yellows and cyans than sRGB. We need to keep it."
sRGB is based on the display characteristics of consumer grade monitors from the late 1990s. Consequently the sRGB color gamut is far too small to hold all printable colors. So Adobe RGB (1998) was hailed as superior to sRGB, particularly when the task at hand was editing printable colors that exceed the very small sRGB color space.
The Adobe RGB (1998) color gamut is also too small to hold all printable colors. But for many editing tasks Adobe RGB (1998) was and still remains an improvement over sRGB.
Adobe RGB (1998) is almost certainly the second most widely used RGB color space, right behind sRGB.
Many commercial print shops only accept sRGB images. Of the shops that do accept images in another RGB color space, that color space is often Adobe RGB (1998).
Most digital cameras only save jpegs in the sRGB color space. Of the ones that do allow the saving of jpegs in another RGB color space, that color space is Adobe RGB (1998).
Adobe RGB (1998) is important for:
* People preparing images for printing
* People who save Adobe RGB (1998) camera jpegs
* People who want or need a small gamut color space that is nonetheless larger than the very small sRGB.
A summary rejection of Adobe RGB (1998) ignores the needs and accustomed workflows of the many, many photographers who work in the Adobe RGB (1998) color space.
Elle
It makes no sense to import opening files with any particular ICC profile, by definition unbounded gamut RGB spaces support storing and manipulating all colors of photo's/imagery of any bounded gamut RGB spaces. What actual color space/pixel format is being used for manipulation is a separate concern from how color data is passed around and actually stored. There are definetely many things to sort out and many things in GIMP that have are straight ports of the old 8bit/component code; keeping track of the _meta_data_ of an original color space/gamut/pixel format raster data originated in - and the ability to to chosen/select operations in that space is something that fits the strongly color managed architecture of GEGL. While doing global overrides of some of the internal pixel formats that are absolutely colorimetrically defined would make it easy to misconfigure the color settings yielding surprising and inconsistent behavior.
The default GEGL/babl pixel formats in floating point are unbounded; and personally I think the 16bit formats should be made 4.12 instead 0.16 fixed point to provide adequate headroom/footroom - though with a predominantely floating point based processing doing this might not be a huge win.
Exporting to any particular bounded RGB gamut; as well as proofing whether colors are within a gamut should in no way be hampered.
The usefulness of the extended range in cyan/green; and how many perceptually discernable colors you gain compared to sRGB is questionable.
Not having saddle adapters as mandatory attachment mechanisms for car seats ignores the needs and accustomed workflows of horse riders used to maintain and customize their leather saddles.
/pippin
Opinion:
Using, internally, a reference unbounded color space (or two: one linear, one perceptual, with, possibly low precision shadows for speed), and converting in and out of it when an image is imported or exported is a sane choice.
Deviations from the "standard internal color space(s)" should be motivated by the operation being performed, not by the color spaces of the initial and final results (which may or may not belong to the same ones in any case).
There are, no doubt, situations in which alternate internal color spaces could give better results. But catering to these corner cases is likely to cause endless headaches for developers and bring no benefit whatsoever to 99.999% of users.
Storage, yes. Unbounded mode sRGB can be used to store any colors. So can any other unbounded mode color space.
Manipulation works for some operations, but not for all operations.
*Some* editing operations work exactly the same in any floating point unbounded mode color space. sRGB is no more and no less special in this regard than any other RGB color space.
Many important editing operations *fail* in unbounded mode sRGB because *the channel data has been rearranged*. I've given concrete examples and provided files so anyone can replicate my findings: http://ninedegreesbelow.com/gimpgit/unbounded-srgb-what-works-what-does-not.html
The shape and distribution of channel data matters.
What pixel formats are absolutely colorimetrically defined?
Could you please explain what you mean by absolute colorimetric? Apart from soft proofing to an output device profile, I'm just not sure how the words "absolute colorimetric" apply in the current context.
? I don't understand what you mean. Is it the user who misconfigures something? Or the code?
My apologies, what do you mean? Are you planning on making 16-bit integer precision actually 12-bit integer or something? Or some kind of hybrid integer-floating point?
Well, I thought I made it clear that I was talking about camera-generated jpegs - that were save to disk by the camera - already in the Adobe RGB (1998) color space. Exporting the image after editing in GIMP, in the color space of the user's choice, is an entirely separate issue.
It might not be a lot of extra gamut, but every little bit helps.
My apologies, I don't understand the analogy.
Elle
It makes sense for lots of people's usual workflow. It's what people do
now with GIMP and other similar tools.
Now, I don't have anything against improved and simplified workflows if
they are transparent to users.
The unbounded gamut thing sounds great if it can be implemented without
breaking the way users work with their files.
And that's my concern (I think Elle's too).
For instance, in Elle's example -the yellow flower with hidden detail in
the blue channel- there's a valid and common use of extra gamut.
Pulling information of channels for creative or technical purposes
shouldn't be ruled out.
It's what artists do, not only for creative black and white, but for
pulling mattes for compositing, among other uses.
And that's just one example.
Our concern (here I'll speak for Elle too, I think she meant the same in her observations) is that way too many things have to be accomodated to work with the unbounded gamut model, both in the application and the users workflow. And in some cases it is uncertain that they will work (I cited the multiply/divide operations giving unusable results)
But if you can guarantee that it's not going to impact on users freedom and expectations, I'll just STFU :-)
I think I understand the idea, and it seems solid... for sRGB, or for images that don't have to go through heavy editing and compositing.
Elle and I have made some tests where the results of working in
unbounded sRGB are really different than doing the same in the original
colorspace (read colorspace here as primaries only, I'm leaving all the
trc conversions out for the sake of simplicity and going straight to the
point).
That seems to indicate that several operations have to be modified in
order to accomodate with working with unbounded values. And they are
operations that would work without modifications in a bounded
colorspace, even for HDR images.
In our conversation over IRC you stated that the same out-of-bounds
values you have in unbounded sRGB are also a problem in HDR files, but
that doesn't seem to be entirely correct.
It's true that HDR images can end up with negative and >1, but in those
images values above 1 NEVER mean out of gamut colors. It means the
saturated primary with more intensity, not for instance "redder than
red"
And those >1 values don't seem to be a problem for compositing or
editing.
Negative values, on the other hand, are always a problem. But in a
scene-referred linear light model, light intensity is supposed to go
between 0 and infinity, so it's quite safe to clip something that means
"negative light intensity" because it's nonsense.
(there are special cases, like the results of convolutions where
negative values are still a problem, but they have to be addressed in a
different way, as you said).
In the unbounded model, the unbounded values mean out of gamut values, and I think (and the tests I did seem to confirm it) that many operations that are designed to mimic how light works in reality will struggle with those values, because they're not anymore counterparts of light (i.e.: the RGB channels are no longer equivalent to 3 colored lamps with variable intensity)
The math of compositing and color operations seems to have been created around that idea, and using a different paradigm for the contents of thr RGB channels probably requires to rethink an important part of those operations.
The concern and the question is if it's worth it. It seems a titanic effort for something that doesn't necessarily mean a huge benefit.
Anyway, it's my personal perception. Maybe I'm getting all this wrong and my concerns are unfounded. I'm totally open to be proven wrong, it's a good way to learn new things :-)
While doing
That's true and I've witnessed that hundreds of times during my carreer
as a designer. Most of the graphic designers I know (who use Adobe)
don't know what to do with the color settings dialog and leave them
untouched, or in the worst cases touch it without knowing what they're
doing.
But you can't just assume that all users won't know what to do with
color profiles.
As I mentioned before in the recent softproofing thread, I'm all for
removing some confusing and error prone elements of the color managed
workflow, but that should result in something the allows a sane color
managed workflow where users have control, not a "transparent" thing
where you only select your output bounded color profile and nothing
else.
As a person whose work consists in sending files to offset print shops weekly, I tend to agree that the AdobeRBG's gamut gain in green is almost irrelevant, and the gain in cyans is marginal, considering the gamut of the usual output colorspaces. I don't think AdobeRGB is that important for general print, but it's still widely used and some specific models of photographic printers seem to be specially tailored towards the green and cyan extra gamut provided by AdobeRGB.
I agree.
Heh, that's not a good argument for something that is more a PR issue than a technical one. People use Adobe. You can't use that argument in a world where people still uses toilet paper :-)
Gez.
(Apologies if I am missing the point.)
What Elle's excellent http://ninedegreesbelow.com/gimpgit/unbounded-srgb-what-works-what-does-not.htmlsuggests to me is that the designer of an operation should choose what color space the operations should internally work in, and convert in and out of it. No more and no less. My impression is that the GEGLized GIMP is structured so that this is feasible without too much work on the operation coder.
I have made this point in another context: Downsample through linear light, for example (unbounded) linear RGB with sRGB primaries or XYZ (unless possibly your sampler is monotone or close to monotone). And preferable upsample through a perceptual colorspace (like Lab or CMC or (unbounded) sRGB).
Elle's examples simply suggest that the "broken" operations do not internally use a good choice of color space, and point to one better choice.
El jue, 17-04-2014 a las 16:48 +0200, Nicolas Robidoux escribió:
Opinion:
It's still not clear (at least for me) what is the impact or the unbounded color values in processing. I'm not pretending I have all the answers, so I'm proposing to discuss it. Elle and I brought a couple of examples where those unbounded values introduce problems, and we didn't get direct answers about them. I think it's not a sane choice pretending that all the cases that don't fit the model are just corner cases. It's quite contradictory to be extremely worried to keep the appearance and behavior of legacy files, and at the same time throw away valid cases of high-end professional editing, labeling them as "corner cases".
It would be interesting to discuss if those cases are really corner cases. Pulling mattes from green/blue screen shots is really common in VFX, and high end cameras usually have way more color latitude than sRGB, what means that an important part of the gamut needed to pull those mattes would end in the out-of-gamut, hence "unbounded" realm.
We're not talking about details invisible to the eye as in Elle's yellow cone flower example.
Please, don't take this as an attack to the project. I'm just sharing my concerns as a commited heavy user of GIMP and free software. In the end I'll respect your decisions even if I don't agree with them, because you guys are doing all the heavy lifting.
Gez.
The conceptual model for the coder is the same as if the images were converted to floating point XYZ on import; and converted to the coders choice of input and output pixelformats before and after. The smaller set of variation needed for the most frequently performed conversions makes things run faster; in particular since data isn't transformed back to XYZ but on demand changed to the next operations desired format instead of copying where a copy nevertheless would take place in the code.
The a building block missing for doing this in GEGL with the smallest effort (more effort on the programmer using GEGL) is two GEGL operations using lcms2 for converting to/from arbitrary ICC profiles. One would also want linear versions of the spaces defined by the ICC profile. These two operations would be placed around the steps with overriden working-space. I offer no opinion about how that would be done in the UI. A lower level integration could permit GEGL operation writers to specify wanting "import profile data"; perhaps linearised - the developer of the op could then even offer some choices up for the autogenerated property UI.
Another way to see this list; is as a list of operations that to some degree were broken in GIMP-2.8. Where all operation happen in a globally dictated 8bpc working-space. Possibly sRGB. Most of these are things that should have happened in linear light but didn't. This is what the strong internal color management of annotating all buffers with the datas relation to linear light RGBA which is strictly defined in relation to XYZ fixes. The cleanup and deciding the most reasonably formats for each operation is a work in progress; parts of GIMPs UI surely could be improved in relation to values that currently are just preserved but not visible/actionable.
/pippin
