Core Features
Core Features Konstantin N.Kozlov 30 Jan 15:09
Core Features Øyvind Kolås 30 Jan 15:34
Konstantin N.Kozlov
2007-01-30 15:09:43 UTC (about 18 years ago)
Core Features
I have just subscribed to this list and would like to say Hello to everybody.
I am working in the field of systems biology and my work includes processing of images and writing software for it also.
I have several questions to the developers about the core features of GEGL.
Can the node have several input and output pads? And can it have zero number of input or output pads?
Where is the result of node execution stored - in memory or in temporal storage on disk?
There are several software packages that use DAG to store the list of operations called workflows or workspaces namely VisiQuest, TiViPe, SCIRUN, SIVIL and probably Matlab/Simulink. The image processing tools and api for nodes/connections are usually separated. What is the reason to put them in one library?
Are there plans to implement distributed processing?
Are there any efforts to implement visual programming environment for creating and editing DAG with GEGL?
Best regards,
Mackoel
Øyvind Kolås
2007-01-30 15:34:11 UTC (about 18 years ago)
Core Features
The current architecture allows both several input and several output pads, though some internal restructuring/maintenance might be needed to support multiple
output pads correctly throughout the system. There are nodes that load/produce image data that have no inputs, as well as nodes that store image data (the png-writer for instance) that have no output pads.
Out of the box GEGL swaps tiles to RAM, by setting the environment variable GEGL_SWAP to any non-zero value it will swap to disk instead and has in such a manner been successfully used for image processing on >12GB image rasters.
Because they are closely connected, image processing operations in GEGL do not necessarily work on the entire image buffers but on the smallest possible sub rectangles needed to compute a desired region of interest. It is also possible to do other optimizations like reordering of operations, changing of parameters according to scale level etc.
This is planned, the first step will perhaps be multiple threads (or processes on a single machine). The tiled buffer architecture of GEGL is designed with network distributed read/write access in mind. When multi-threaded/distributed processing becomes possible the aim is that this should happen without changes to the public API. Thus existing tools built on top of GEGL should automatically get the same capabilities without any code changes.
Right now the closest thing is the tree based test app the comes with GEGL. It implements a proxy between the graph and a tree (which allows clones, but not editing of them yet). A tree with clones can represent any DAG as long as you do not allow multiple output pads for any of the nodes. (all nodes have a single "output" pad).
I've got an old graph editor[1] from the gggl[2] project (gggl has now been assimilated by GEGL). Which I probably will resurrect at some point.
Thank you for your interest.
/Øyvind K.
1: http://people.freedesktop.org/~pippin/cairo/bauxite_0_86.png 2: http://pippin.gimp.org/gggl/
