Two questions about updating GIMP from git
Two questions about updating GIMP from git Elle Stone 10 Mar 15:44
  Two questions about updating GIMP from git Shlomi Fish 10 Mar 19:17
   Two questions about updating GIMP from git Elle Stone 11 Mar 11:37
    Two questions about updating GIMP from git Michael Henning 11 Mar 23:53
Elle Stone
2014-03-10 15:44:23 UTC (about 11 years ago)
I update three separate copies of babl/gegl/gimp from git, each in a prefix, on average once a week.
Other than reading the git logs, is there an easy way to check to see whether software requirements (png, tiff, glib, etc) have been bumped up?
Also, I've been updating command by command in a virtual terminal and my computer isn't very fast. I'd like to write a script that executes all the commands all at once, but exits with an informative error message printed to screen as soon as something doesn't configure, compile, or install properly. Does anyone have such a script or know how to write one?
Elle
Shlomi Fish
2014-03-10 19:17:20 UTC (about 11 years ago)
Hi Elle,
This should be doable with a script written in Shell, Perl 5, Python, Ruby, etc. by inspecting the status exit code of the command.
E.g: in Bash:
if ! ./configure $PARAMS > configure.log 2>&1 ; then echo "Configure command failed"
exit -1
fi
(Untested!)
There may be a ready made solution, but writing something quick yourself would probably be less time consuming.
Shlomi Fish
Shlomi Fish       http://www.shlomifish.org/
Chuck Norris/etc. Facts - http://www.shlomifish.org/humour/bits/facts/
I also have versions of this code in COBOL.NET, Intercal, PDP‐10 Assembly, J,
APL, Windows NT 4.0 Batch script and Autocad Lisp — I’m sure you can handle
all of them because none of them is Perl. ;-).
Please reply to list if it's a mailing list post - http://shlom.in/reply .
Elle Stone
2014-03-11 11:37:09 UTC (about 11 years ago)
Shlomi Fish and SorinN,
Thanks! With examples to work from, hopefully it won't be too hard to write a script that makes updating GIMP easier.
Elle
Michael Henning
2014-03-11 23:53:31 UTC (about 11 years ago)
Here are two scripts that I use to help keep git up to date. The first updates my git checkouts, and the second cleans out any build files (which is useful to run from time to time). They require $SRC_DIR to be set to the directory that your babl/gegl/gimp checkouts are under, and $INSTALL_PREFIX must be the location of your install prefix.
The main key to these script is that the first line is "#!/bin/bash -e". The -e argument to bash means that if any command in the script fails, then the script will exit immediately, instead of continuing to the next command.
upd.sh:
#!/bin/bash -e
build () { cd $SRC_DIR/$1
git pull --rebase
if [ ! -f ./Makefile ]; then
./autogen.sh --prefix=$INSTALL_PREFIX --enable-fast-install $2 fi
make
make install
build babl
build gegl "--enable-gtk-doc --enable-debug" build gimp
clean.sh:
#!/bin/bash
rm -r $INSTALL_PREFIX mkdir $INSTALL_PREFIX
clean () { cd $SRC_DIR/$1
git clean -Xdf
git pull --rebase
clean babl
clean gegl
clean gimp
Hopefully this helps.
-- drawoc
Elle
