Jenkins infrastructure (Was: Jenkins tutorial)
18 of 19 messages available
Jenkins infrastructure (Was: Jenkins tutorial) scl 23 Feb 10:05
  CAKtEXLDQN2Xn=RUPqhFbAhhD9f... 24 Feb 19:09
   Jenkins infrastructure (Was: Jenkins tutorial) scl 24 Feb 19:09
    Jenkins infrastructure (Was: Jenkins tutorial) Sam Gleske 24 Feb 21:39
     Jenkins infrastructure (Was: Jenkins tutorial) Michael Schumacher 24 Feb 22:27
      Jenkins infrastructure (Was: Jenkins tutorial) scl 27 Feb 05:03
       Jenkins infrastructure (Was: Jenkins tutorial) Michael Schumacher 27 Feb 08:18
        Jenkins infrastructure (Was: Jenkins tutorial) scl 27 Feb 19:10
         Jenkins infrastructure (Was: Jenkins tutorial) Michael Schumacher 27 Feb 22:51
       Jenkins infrastructure (Was: Jenkins tutorial) Sam Gleske 27 Feb 21:36
        Jenkins infrastructure (Was: Jenkins tutorial) scl 28 Feb 04:28
         Jenkins infrastructure (Was: Jenkins tutorial) Sam Gleske 28 Feb 13:27
     Jenkins infrastructure (Was: Jenkins tutorial) scl 01 Mar 17:49
      Jenkins infrastructure (Was: Jenkins tutorial) Sam Gleske 02 Mar 03:33
       Jenkins infrastructure (Was: Jenkins tutorial) Sam Gleske 02 Mar 03:39
  Jenkins infrastructure (Was: Jenkins tutorial) scl 24 Feb 05:05
   Jenkins infrastructure (Was: Jenkins tutorial) Sam Gleske 24 Feb 14:13
scl
2014-02-23 10:05:33 UTC (about 11 years ago)
On 23.2.2014 at 12:47 AM Sam Gleske wrote: > Also, something you might be interested in is front end web testing > for bad
> links, etc. Recently I've been working on a project to facilitate > that testing.
> https://github.com/sag47/frontend_qa >
> This can easily be used in a Jenkins job to arbitrarily launch and crawl > gimp.org and test all the links in it checking for dead links, etc. > Currently it's a work in progress but it's a place that one can easily > start for frontend testing the Gimp website.
Thank you for your offer. I have such a topic on my todo list and have planned to add it after improving the nightly and continuous builds. Jenkins opens such a bunch of new opportunities for our release process and I think I'll speak about it at our LGM BOF meeting.
But if you have sth. stable for production use and are willing to contribute it in form of a Jenkins job, I'll be glad to integrate it. I think our both wikis (wiki.gimp.org, gui.gimp.org) would benefit from such a test, too.
Schumaml, Prokoudine etc.: what are your thoughts or requirements about it?
On 23.2.2014 at 12:51 AM Sam Gleske wrote: > That being said... would it be useful to have a vagrant instance of > the development environment including Jenkins for Job testing? > With a vagrant file it can be as easy as a single program executing > to pull down virtual box, the image, all of the requirements for gimp > building and testing.
> This is something which could also be tweaked.
Indeed, that idea has its charm ;-) I'm currently considering to improve the Jenkins infrastructure to support multiple build slaves of various operating systems and other improvements. So the idea of Vagrant and other Devops tools like Puppy or Chef comes to just the right time. Let's see how we can make the best of it. What does GNOME use - Puppy or Chef? Cameron, do you see a possibility to easily start and setup Virtualbox VMs for Jenkins master and build slaves with tools like Vagrant, Chef or Puppy in the Flamingtext infrastructure, that also comes to terms Flamingtext's interests?
Also the idea of a standardised development environment for GIMP to get new contributors started quickly has been something I had in mind for long (see below).
> Also, Jenkins really isn't > hard. It's pretty intuitive IMO (java -jar jenkins.jar and you have a > local web server) but a turn key dev environment would certainly > lower the barrier to entry.
From the experiences I've made since I took over Jenkins administration in the GIMP project this is surely true for the first step of installing Jenkins. The hard work starts when one tries to setup a complex environment for many, interdependent build products or platforms and to integrate it into a bigger infrastructure. Also building GIMP for the first times and/or on other platforms than plain Debian Testing is a hurdle most times, even for new contributors. This is also an argument for a dedicated GIMP developer VM.
Kind regards,
scl
2014-02-24 05:05:19 UTC (about 11 years ago)
I'm currently considering using Python, Perl or a JVM based scripting language (Groovy etc.) for the buildjobs. The goal are platform independence, performance and easy maintainability.
Without wanting to start a silly flamewar about which tool is the greatest:
- Where are the experienced benefits and downsides of these languages for the desired task?
- Which readings would you recommend for Python and the JVM based language?
Thank you in advance,
Sam Gleske
2014-02-24 14:13:15 UTC (about 11 years ago)
I don't have any Groovy experience but I can say that the Docs on python.orgare great for learning Python. See their tutorial which includes best
practices for the language and other tid bits.
http://docs.python.org/2/tutorial/index.html
scl
2014-02-24 19:09:06 UTC (about 11 years ago)
Forwarded with Sam Gleske's permission: On 24.2.2014 at 3:21 PM Sam Gleske wrote:
On Sun, Feb 23, 2014 at 5:05 AM, scl > wrote:
But if you have sth. stable for production use and are willing to contribute it in form of a Jenkins job, I'll be glad to integrate it. I think our both wikis (wiki.gimp.org , gui.gimp.org ) would benefit
I'm not familiar with the shorthand "sth". I can start running tests against www.gimp.org and begin to start ironing out bugs which would need to be fixed in my program. I've run into bugs here and there running my crawler against large websites. Right now I've crawled and run against Drexel University IRT website using the crawler which is ~70k links. I'll do it for www.gimp.org too and then contribute a Job when I have it ready (and for the other GIMP websites as well).
I don't know whether this could cause technical problems for www.gimp.org. The reason why I wrote 'something stable for production use' is that I want to avoid just them ;-) Thus it would be good to hear our website administrators opinion to that.
Also, I'd like to note that
if you're not using git hooks now would be a good time to use them. Rather than using Jenkins to constantly poll the SCM simply implement a hook to launch a Jenkins job when a certain branch is committed to.
Currently we're polling SCM every few minutes. Adding a git hook to the repository would surely need involvement of the GNOME administrators. Is there a good reason to switch over from polling to hooking?
Greetings,
Sam Gleske
2014-02-24 21:39:59 UTC (about 11 years ago)
Both the crawler and the tests following it support a --request-delay. Requests can be arbitrarily delayed by 0.3 seconds (smaller or larger if chosen) so as to mitigate impact of the website. I won't run any tests against the GIMP website until I get permission to do so. Also, currently my testing suite support saving crawl data in a JSON format. The advantage of this would be separating the crawl from the actual testing (if that's desired later on). Currently I mostly use it to debug my test suite because crawling can take a bit of time so saving that data allows me to avoid that step.
The advantage of hooks vs polling is that hooks are on demand. i.e. a job or process is only launched if there is an actual commit. For the sake of covering all topics I'll briefly describe polling. Polling simply keeps checking the state of the repository periodically (e.g. every 5 minutes). If the state hasn't changed (no commits) then it does nothing. If the state has changed (i.e. commits have been made) then it executes based on what was defined for the Job.
Hooks simply take less processing time. On a smaller scale they save energy because they're not constantly polling. It's also lowering the request load of the server serving the repository being polled. It's not a big deal if a server is serving a single repository or a few repositories. However, when you have e.g. 10000 repositories on a server the polling request load of each repository every few minutes starts to eat up the server's ability to serve. For smaller servers it's not the end of the world to have polling because it is easier to implement. I realize the GIMP project may be only a small part of that ecosystem being served but it is something worth considering.
SAM
2014-02-24 22:27:16 UTC (about 11 years ago)
I guess the website can handle this, especially if the crawling only happens when...
...a commit hook triggers it. With some suitable delay - right now this would better be days, until we finally overcome the laziness and set up a commit-triggered website build on cube again :)
scl
2014-02-27 05:03:59 UTC (about 11 years ago)
On 24.2.2014 at 11:27 PM Michael Schumacher wrote:> On 24.02.2014 22:39, Sam Gleske wrote:
how about building the website on Jenkins, too? This would unfetter us from asking regularly in IRC whether 'somebody is around who can update the website', i.e. streamline our website maintenance process. The newly generated website could then be fetched the same way like the we currently do with the API docs. To still be able to review the commits we could agree to either use a separate branch (a review branch or feature branch) or commit patches only via Bugzilla, or we later use a review tool like [Gerrit] (in co-ordination with GNOME).
Kind regards,
[Gerrit] https://code.google.com/p/gerrit/
2014-02-27 08:18:44 UTC (about 11 years ago)
On IRC, I've asked for hints about how to get this back to the old commit triggered workflow on cube, but don't remember any replies. I'm pretty sure this can't be much work.
The build time itself is less than 30 seconds, abigger tipic is to discuss what we want on the site.
Manually, unless this has changed since the last time I updated it?
This is why I recently asked mitch about resurrecting/creating at least one other virtual host for creative testing.
We need more discussion about some things, at least. Getting a 'Help, what is this going to achieve?' feeling for a new tutorial like thr most recent one isn't optimal, especially if it makes us postpone a site update.
I think we should start to have semi-regular meetings on IRC, logged and those logs published.
scl
2014-02-27 19:10:38 UTC (about 11 years ago)
I was under the assumption that it's automatic now, but I might be wrong.
... for the website or more stuff?
Indeed. I think for now we can revert the last three blocking commits in gimp-web and take the tutorial to the wiki when it's finished.
Yes, it was started once in 2011, but then it came to nothing (see the Developer meetings in our wiki). Did it work in the past? If we can speed up urgent topics and can all be at a given time in IRC, it's at least worth a try.
Kind regards,
Sam Gleske
2014-02-27 21:36:50 UTC (about 11 years ago)
Testing the website can be part of the build process in the Jenkins job (or calling another job which does the testing upon a successful build of the website job).
Also, when do IRC meetings happen and can anyone participate? What server and channel? http://www.gimp.org/irc
SAM
2014-02-27 22:51:37 UTC (about 11 years ago)
Website. There are some changes, in particular to the site creation code itself, that I don't want to do to a live site.
scl
2014-02-28 04:28:29 UTC (about 11 years ago)
We're in #gimp at irc.gimp.org, usually in evening hours (UTC).
GIMP users' discussions are in #gimp-users and GEGL development discussions in #gegl.
Kind regards,
Sam Gleske
2014-02-28 13:27:59 UTC (about 11 years ago)
Cool, when I do join I'll be user sag47. I say that because my user will be different than my email on the list.
SAM
scl
2014-03-01 17:49:38 UTC (about 11 years ago)
together with Andrea Veri I've set up the hook based build trigger. Currently it is active for testing purposes on the branches babl/hooktest and GEGL/master. If we encounter no trouble the other branches will follow in one week or two.
That's how it works: 1. You push a commit to babl/hooktest or GEGL/master in our public repository.
2. Git's Post-Receive hook notifies Jenkins about changes in the affected repository and branch.
3. Jenkins' Git Plugin will scan all the jobs which check out the specified URL and if they are configured with polling, they'll poll. 4. The polling will usually find something that's worth a build, so a build will be triggered.
5. You get an answer about success or failure of your commit via IRC and RSS (quicker than before)
For more information see: https://wiki.jenkins-ci.org/display/JENKINS/Git+Plugin http://kohsuke.org/2011/12/01/polling-must-die-triggering-jenkins-builds-from-a-git-hook/
Thanks to Sam Gleske for the advice and Andrea Veri for setting up the Git side.
Kind regards,
Sam Gleske
2014-03-02 03:33:51 UTC (about 11 years ago)
On Sat, Mar 1, 2014 at 12:49 PM, scl wrote:On Mon, Feb 24, 2014 at 2:09 PM, scl wrote:
For more information see: https://wiki.jenkins-ci.org/display/JENKINS/Git+Plugin http://kohsuke.org/2011/12/01/polling-must-die-triggering- jenkins-builds-from-a-git-hook/
+1 Awesome.
@gimp-dev, @gimp-web My crawler has a stable release now. I'd like to request permission to crawl www.gimp.org. It will be restricted to that domain and have request delays implemented to minimize impact.
SAM
Sam Gleske
+1 Awesome.
SAM
Sam Gleske
2014-03-02 03:39:39 UTC (about 11 years ago)
FYI most of the requests will only be HTTP method HEAD - http://www.w3.org/Protocols/rfc2616/rfc2616-sec9.html#sec9.4
It only requests headers and not the response body so it would actually be less of an impact than most crawlers when doing the actual link testing. For the crawling itself the response body is received so that it can find other links.
SAM
Sam Gleske
SAM
