How Does One Call An Existing PDB Procedure From A C Plug-in?
How Does One Call An Existing PDB Procedure From A C Plug-in? stormy@franchise5000.com 04 Feb 00:44
  How Does One Call An Existing PDB Procedure From A C Plug-in? Simon Budig 04 Feb 02:07
   How Does One Call An Existing PDB Procedure From A C Plug-in? stormy@franchise5000.com 04 Feb 08:28
2014-02-04 00:44:14 UTC (about 11 years ago)
How do I access existing PDB procedures from a C plug-in? I'm very familiar with how this is done in Scheme & Python. I'm confused on how this is accomplished in C.
Can someone explain how this is done and/or provide a link to an example of a C plug-in that calls an existing procedure in the PDB?
Many Thanks!
Simon Budig
2014-02-04 02:07:58 UTC (about 11 years ago)
Look for "gimp_run_procedure".
One example is in file-ico.c:
return_vals = gimp_run_procedure ("plug-in-threshold-alpha", &n_return_vals, GIMP_PDB_INT32, GIMP_RUN_NONINTERACTIVE, GIMP_PDB_IMAGE, tmp_image, GIMP_PDB_DRAWABLE, tmp_layer, GIMP_PDB_INT32, ICO_ALPHA_THRESHOLD, GIMP_PDB_END); gimp_destroy_params (return_vals, n_return_vals);
I hope this helps.
Bye, Simon
simon@budig.de              http://simon.budig.de/
2014-02-04 08:28:48 UTC (about 11 years ago)
I hope this helps.
Bye, Simon
simon@budig.de http://simon.budig.de/ _______________________________________________
Thank you. That is very helpful.
~Stormy
