git babl build breaks due to random() and srandom()
git babl build breaks due to random() and srandom() Partha Bagchi 01 Feb 17:42
  git babl build breaks due to random() and srandom() Daniel Sabo 02 Feb 04:28
   git babl build breaks due to random() and srandom() Partha Bagchi 02 Feb 05:44
Partha Bagchi
2014-02-01 17:42:34 UTC (about 11 years ago)
The latest git pull for babl braks for me. I am not sure if random()/srandom() is standard as it is undefined on my system (gcc 4.8.1 with Msys). I changed it to rand()/srand().
I do get the following warning (repeated a few times): babl-gen-test-pixels.c:55:9: warning: unknown conversion type character 'a' in format [-Wformat=]
Thanks,
Partha
Daniel Sabo
2014-02-02 04:28:50 UTC (about 11 years ago)
Could you check that this patch resolves the issue?
https://bugzilla.gnome.org/show_bug.cgi?id=723461
Partha Bagchi
2014-02-02 05:44:51 UTC (about 11 years ago)
Hi Daniel,
Applied the patch, but fails since you also need to account for random used in tests/babl_fish_path_fitness.c
Thanks, Partha
