[PATCH v2] Optimize operation box-blur opencl kernel
[PATCH v2] Optimize operation box-blur opencl kernel Yongjia Zhang 23 Jan 02:45
  [PATCH v2] Optimize operation box-blur opencl kernel Victor Oliveira 31 Jan 02:49
Yongjia Zhang
2014-01-23 02:45:18 UTC (about 11 years ago)
This is a better way to accomplish the box-blur cl operation by using ocl's local memory from the opencv source code. It use the local shared memory to reduce global memory access, which significantly reduces the kernel's processing time by 70 percent compared to the original one. Because of the barriers and local worksize limitation, processing with a radius larger than 110 becomes slower than original algorithm, so I keep the original kernels in order to deal with box-blur with radius larger than 110. All the tests are based on Intel Beginet and Intel IvyBridge CPU and GPU.
v2:add kernel attribute to restrict the local size to (256,1,1).
Signed-off-by: Yongjia Zhang ---
opencl/box-blur.cl | 68 +++++++++++++++++++++++++ opencl/box-blur.cl.h | 68 +++++++++++++++++++++++++ operations/common/box-blur.c | 115 ++++++++++++++++++++++++++----------------- 3 files changed, 205 insertions(+), 46 deletions(-)
diff --git a/opencl/box-blur.cl b/opencl/box-blur.cl index e99bea4..0d64c89 100644
--- a/opencl/box-blur.cl
+++ b/opencl/box-blur.cl
@@ -43,3 +43,71 @@ __kernel void kernel_blur_ver (__global const float4 *aux, out[out_index] = mean / (float)(2 * radius + 1); }
+__kernel
+__attibute__((reqd_work_group_size(256,1,1))) +void kernel_box_blur_fast(const __global float4 *in, + __global float4 *out, + __local float4 *column_sum, + const int width, + const int height, + const int radius, + const int size) +{ + const int local_id0 = get_local_id(0); + const int twice_radius = 2 * radius; + const int in_width = twice_radius + width; + const int in_height = twice_radius + height; + const float4 area = (float4)( (twice_radius+1) * (twice_radius+1) ); + int column_index_start,column_index_end; + int y = get_global_id(1) * size; + const int out_x = get_group_id(0) + * ( get_local_size(0) - twice_radius ) + local_id0 - radius; + const int in_x = out_x + radius; + int tmp_size = size; + int tmp_index = 0; + float4 tmp_sum = (float4)0.0f; + float4 total_sum = (float4)0.0f; + if( in_x < in_width ) + { + column_index_start = y; + column_index_end = y + twice_radius; + for( int i=0; i< width ) + { + if( local_id0 >= radius + && local_id0 < get_local_size(0) - radius ) + { + total_sum = (float4)0.0f; + for( int i=0; i< in_width ) + { + tmp_sum = column_sum[local_id0]; + tmp_sum -= in[(column_index_start)*in_width+in_x]; + tmp_sum += in[(column_index_end+1)*in_width+in_x]; + ++column_index_start; + ++column_index_end; + column_sum[local_id0] = tmp_sum; + }
+ barrier( CLK_LOCAL_MEM_FENCE ); + } +} diff --git a/opencl/box-blur.cl.h b/opencl/box-blur.cl.h index bfed601..e4585ec 100644
--- a/opencl/box-blur.cl.h
+++ b/opencl/box-blur.cl.h
@@ -44,4 +44,72 @@ static const char* box_blur_cl_source = " out[out_index] = mean / (float)(2 * radius + 1); \n" " } \n" "} \n" +" \n" +"__kernel \n" +"__attribute__((reqd_work_group_size(256,1,1))) \n" +"void kernel_box_blur_fast(const __global float4 *in, \n" +" __global float4 *out, \n" +" __local float4 *column_sum, \n" +" const int width, \n" +" const int height, \n" +" const int radius, \n" +" const int size) \n" +"{ \n" +" const int local_id0 = get_local_id(0); \n" +" const int twice_radius = 2 * radius; \n" +" const int in_width = twice_radius + width; \n" +" const int in_height = twice_radius + height; \n" +" const float4 area = (float4)( (twice_radius+1) * (twice_radius+1) ); \n" +" int column_index_start,column_index_end; \n" +" int y = get_global_id(1) * size; \n" +" const int out_x = get_group_id(0) \n" +" * ( get_local_size(0) - twice_radius ) + local_id0 - radius; \n" +" const int in_x = out_x + radius; \n" +" int tmp_size = size; \n" +" int tmp_index = 0; \n" +" float4 tmp_sum = (float4)0.0f; \n" +" float4 total_sum = (float4)0.0f; \n" +" if( in_x < in_width ) \n" +" { \n" +" column_index_start = y; \n" +" column_index_end = y + twice_radius; \n" +" for( int i=0; i< width ) \n" +" { \n" +" if( local_id0 >= radius \n" +" && local_id0 < get_local_size(0) - radius ) \n" +" { \n" +" total_sum = (float4)0.0f; \n" +" for( int i=0; i< in_width ) \n" +" { \n" +" tmp_sum = column_sum[local_id0]; \n" +" tmp_sum -= in[(column_index_start)*in_width+in_x]; \n" +" tmp_sum += in[(column_index_end+1)*in_width+in_x]; \n" +" ++column_index_start; \n" +" ++column_index_end; \n" +" column_sum[local_id0] = tmp_sum; \n" +" } \n" +" \n" +" barrier( CLK_LOCAL_MEM_FENCE ); \n" +" } \n" +"} \n" ;
diff --git a/operations/common/box-blur.c b/operations/common/box-blur.c index afc19ea..cb77ec0 100644
--- a/operations/common/box-blur.c
+++ b/operations/common/box-blur.c
@@ -180,9 +180,7 @@ static void prepare (GeglOperation *operation) #include "buffer/gegl-buffer-cl-iterator.h"
#include "opencl/box-blur.cl.h"
static GeglClRunData *cl_data = NULL; -
static gboolean
cl_box_blur (cl_mem in_tex, cl_mem aux_tex, @@ -192,57 +190,82 @@ cl_box_blur (cl_mem in_tex, gint radius) {
cl_int cl_err = 0;
- size_t global_ws_hor[2], global_ws_ver[2]; - size_t local_ws_hor[2], local_ws_ver[2]; -
+ size_t global_ws_hor[2], global_ws_ver[2], global_ws[2]; + size_t local_ws_hor[2], local_ws_ver[2], local_ws[2]; + size_t step_size ;
if (!cl_data)
- const char *kernel_name[] = {"kernel_blur_hor", "kernel_blur_ver", NULL}; + const char *kernel_name[] = { "kernel_blur_hor", "kernel_blur_ver","kernel_box_blur_fast", NULL}; cl_data = gegl_cl_compile_and_build (box_blur_cl_source, kernel_name); }
if (!cl_data)
return TRUE;
- local_ws_hor[0] = 1;
- local_ws_hor[1] = 256;
- global_ws_hor[0] = roi->height + 2 * radius; - global_ws_hor[1] = ((roi->width + local_ws_hor[1] -1)/local_ws_hor[1]) * local_ws_hor[1]; -
- local_ws_ver[0] = 1;
- local_ws_ver[1] = 256;
- global_ws_ver[0] = roi->height;
- global_ws_ver[1] = ((roi->width + local_ws_ver[1] -1)/local_ws_ver[1]) * local_ws_ver[1]; -
- cl_err = gegl_cl_set_kernel_args (cl_data->kernel[0], - sizeof(cl_mem), (void*)&in_tex, - sizeof(cl_mem), (void*)&aux_tex, - sizeof(cl_int), (void*)&roi->width, - sizeof(cl_int), (void*)&radius, - NULL); - CL_CHECK;
- cl_err = gegl_clEnqueueNDRangeKernel (gegl_cl_get_command_queue (), - cl_data->kernel[0], 2, - NULL, global_ws_hor, local_ws_hor, - 0, NULL, NULL); - CL_CHECK;
- cl_err = gegl_cl_set_kernel_args (cl_data->kernel[1], - sizeof(cl_mem), (void*)&aux_tex, - sizeof(cl_mem), (void*)&out_tex, - sizeof(cl_int), (void*)&roi->width, - sizeof(cl_int), (void*)&radius, - NULL); - CL_CHECK;
- cl_err = gegl_clEnqueueNDRangeKernel (gegl_cl_get_command_queue (), - cl_data->kernel[1], 2, - NULL, global_ws_ver, local_ws_ver, - 0, NULL, NULL); - CL_CHECK;
+ step_size = 64;
+ local_ws[0]=256;
+ local_ws[1]=1;
+ if( radius width + local_ws[0] - 2 * radius - 1) / ( local_ws[0] - 2 * radius ) * local_ws[0]; + global_ws[1] = (roi->height + step_size - 1) / step_size; + cl_err = gegl_cl_set_kernel_args(cl_data->kernel[2], + sizeof(cl_mem), (void *)&in_tex, + sizeof(cl_mem), (void *)&out_tex, + sizeof(cl_float4)*local_ws[0], (void *)NULL, + sizeof(cl_int), (void *)&roi->width, + sizeof(cl_int), (void *)&roi->height, + sizeof(cl_int), (void *)&radius, + sizeof(cl_int), (void *)&step_size, NULL); + CL_CHECK;
+ cl_err = gegl_clEnqueueNDRangeKernel(gegl_cl_get_command_queue(), + cl_data->kernel[2], 2, + NULL, global_ws, local_ws, 0, NULL, NULL ); + CL_CHECK;
+ else
+ local_ws_hor[0] = 1;
+ local_ws_hor[1] = 256;
+ global_ws_hor[0] = roi->height + 2 * radius; + global_ws_hor[1] = ((roi->width + local_ws_hor[1] -1)/local_ws_hor[1]) * local_ws_hor[1]; +
+ local_ws_ver[0] = 1;
+ local_ws_ver[1] = 256;
+ global_ws_ver[0] = roi->height; + global_ws_ver[1] = ((roi->width + local_ws_ver[1] -1)/local_ws_ver[1]) * local_ws_ver[1]; +
+ cl_err = gegl_cl_set_kernel_args (cl_data->kernel[0], + sizeof(cl_mem), (void*)&in_tex, + sizeof(cl_mem), (void*)&aux_tex, + sizeof(cl_int), (void*)&roi->width, + sizeof(cl_int), (void*)&radius, + NULL); + CL_CHECK;
+ cl_err = gegl_clEnqueueNDRangeKernel (gegl_cl_get_command_queue (), + cl_data->kernel[0], 2, + NULL, global_ws_hor, local_ws_hor, + 0, NULL, NULL); + CL_CHECK;
+ cl_err = gegl_cl_set_kernel_args (cl_data->kernel[1], + sizeof(cl_mem), (void*)&aux_tex, + sizeof(cl_mem), (void*)&out_tex, + sizeof(cl_int), (void*)&roi->width, + sizeof(cl_int), (void*)&radius, + NULL); + CL_CHECK;
+ cl_err = gegl_clEnqueueNDRangeKernel (gegl_cl_get_command_queue (), + cl_data->kernel[1], 2, + NULL, global_ws_ver, local_ws_ver, + 0, NULL, NULL); + CL_CHECK;
return FALSE;
1.8.3.2
Victor Oliveira
2014-01-31 02:49:21 UTC (about 11 years ago)
OK, I just accepted the patch.
+__kernel
#include "opencl/box-blur.cl.h" -
static gboolean
cl_int cl_err = 0;
if (!cl_data)
if (!cl_data)
return TRUE;
+ step_size = 64;
+ local_ws[0]=256;
+ local_ws[1]=1;
+ else
return FALSE;
-- 1.8.3.2
_______________________________________________ gegl-developer-list mailing list
List address: gegl-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gegl-developer-list
