[PATCH] Add opencl implementation of operation channel-mixer
[PATCH] Add opencl implementation of operation channel-mixer Yongjia Zhang 22 Jan 08:26
  [PATCH] Add opencl implementation of operation channel-mixer Victor Oliveira 22 Jan 19:13
   [PATCH] Add opencl implementation of operation channel-mixer Daniel Sabo 22 Jan 20:41
    [PATCH] Add opencl implementation of operation channel-mixer Victor Oliveira 31 Jan 02:53
Yongjia Zhang
2014-01-22 08:26:42 UTC (about 11 years ago)
Although function gegl_chant_class_init had set operation_class->opencl_support=yes in source file channel-mixer.c, it didn't have a opencl implementation of operation channel-mixer.
In the cpu version of channel-mixer, all needed information is calculated using variable type double. Since gegl_cl_compile_and_build does not take opencl kernel build options, this implementation uses type float instead of double. If build options could be taken, query the device capability of cl_khr_fp64 extension and then select the proper variable type would be the best.
Signed-off-by: Yongjia Zhang ---
opencl/channel-mixer.cl | 40 ++++++++++++++++++++ opencl/channel-mixer.cl.h | 41 ++++++++++++++++++++ operations/common/channel-mixer.c | 80 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 161 insertions(+)
create mode 100644 opencl/channel-mixer.cl create mode 100644 opencl/channel-mixer.cl.h
diff --git a/opencl/channel-mixer.cl b/opencl/channel-mixer.cl new file mode 100644
index 0000000..2fb899c
--- /dev/null
+++ b/opencl/channel-mixer.cl
@@ -0,0 +1,40 @@
+#define CM_MIX_PIXEL( ch, r, g, b, norm ) \ + c = ch.x * r + ch.y * g + ch.z * b; \ + c *= norm; \ + mix_return = fmin( 1.0f, fmax( 0.0f, c ) ); + +__kernel void cl_channel_mixer(__global const float *in, + __global float *out, + float4 ch_red, + float4 ch_green, + float4 ch_blue, + float4 ch_black, + float red_norm, + float green_norm, + float blue_norm, + float black_norm, + int monochrome, + int has_alpha) +{ + const int step = (has_alpha == 0 ? 3 : 4 ); + const int offset = get_global_id(0) * step; + float mix_return = 0.0f; + float c = 0.0f; + if( monochrome ) + { + CM_MIX_PIXEL( ch_black, in[offset], in[offset+1], in[offset+2], black_norm ); + out[offset] = out[offset+1] = out[offset+2] = mix_return; + } + else + { + CM_MIX_PIXEL( ch_red, in[offset], in[offset+1], in[offset+2], red_norm ); + out[offset] = mix_return; + CM_MIX_PIXEL( ch_green, in[offset], in[offset+1], in[offset+2], green_norm ); + out[offset+1] = mix_return; + CM_MIX_PIXEL( ch_blue, in[offset], in[offset+1], in[offset+2], blue_norm ); + out[offset+2] = mix_return; + } + if( 4==step ) + out[offset+3] = in[offset+3]; +} +
diff --git a/opencl/channel-mixer.cl.h b/opencl/channel-mixer.cl.h new file mode 100644
index 0000000..32e12d6
--- /dev/null
+++ b/opencl/channel-mixer.cl.h
@@ -0,0 +1,41 @@
+static const char* channel_mixer_cl_source = +"#define CM_MIX_PIXEL( ch, r, g, b, norm ) \\\n" +" c = ch.x * r + ch.y * g + ch.z * b; \\\n" +" c *= norm; \\\n" +" mix_return = fmin( 1.0f, fmax( 0.0f, c ) ); \n" +" \n" +"__kernel void cl_channel_mixer(__global const float *in, \n" +" __global float *out, \n" +" float4 ch_red, \n" +" float4 ch_green, \n" +" float4 ch_blue, \n" +" float4 ch_black, \n" +" float red_norm, \n" +" float green_norm, \n" +" float blue_norm, \n" +" float black_norm, \n" +" int monochrome, \n" +" int has_alpha) \n" +"{ \n" +" const int step = (has_alpha == 0 ? 3 : 4 ); \n" +" const int offset = get_global_id(0) * step; \n" +" float mix_return = 0.0f; \n" +" float c = 0.0f; \n" +" if( monochrome ) \n" +" { \n" +" CM_MIX_PIXEL( ch_black, in[offset], in[offset+1], in[offset+2], black_norm ); \n" +" out[offset] = out[offset+1] = out[offset+2] = mix_return; \n" +" } \n" +" else \n" +" { \n" +" CM_MIX_PIXEL( ch_red, in[offset], in[offset+1], in[offset+2], red_norm ); \n" +" out[offset] = mix_return; \n" +" CM_MIX_PIXEL( ch_green, in[offset], in[offset+1], in[offset+2], green_norm ); \n" +" out[offset+1] = mix_return; \n" +" CM_MIX_PIXEL( ch_blue, in[offset], in[offset+1], in[offset+2], blue_norm ); \n" +" out[offset+2] = mix_return; \n" +" } \n" +" if( 4==step ) \n" +" out[offset+3] = in[offset+3]; \n" +"} \n" +;
diff --git a/operations/common/channel-mixer.c b/operations/common/channel-mixer.c index cfa7858..ac317de 100644
--- a/operations/common/channel-mixer.c +++ b/operations/common/channel-mixer.c @@ -275,6 +275,85 @@ process (GeglOperation *op, return TRUE;
+#include "opencl/gegl-cl.h"
+#include "opencl/channel-mixer.cl.h" +
+static GeglClRunData *cl_data = NULL; +
+static gboolean
+cl_process(GeglOperation *op,
+ cl_mem in_tex,
+ cl_mem out_tex,
+ glong samples,
+ const GeglRectangle *roi, + gint level)
+ GeglChantO *o = GEGL_CHANT_PROPERTIES(op); + CmParamsType *mix = (CmParamsType *)o->chant_data; + float red_norm, green_norm, blue_norm, black_norm; + cl_float4 ch_red, ch_green, ch_blue, ch_black; + int global_ws[]={samples};
+ g_assert( mix != NULL );
+ red_norm = (float)cm_calculate_norm(mix, &mix->red); + green_norm = (float)cm_calculate_norm(mix, &mix->green); + blue_norm = (float)cm_calculate_norm(mix, &mix->blue); + black_norm = (float)cm_calculate_norm(mix, &mix->black); +
+ /*Convert double to float*/
+ ch_red.s[0] = (float)mix->red.red_gain; + ch_red.s[1] = (float)mix->red.green_gain; + ch_red.s[2] = (float)mix->red.blue_gain; + ch_green.s[0] = (float)mix->green.red_gain; + ch_green.s[1] = (float)mix->green.green_gain; + ch_green.s[2] = (float)mix->green.blue_gain; + ch_blue.s[0] = (float)mix->blue.red_gain; + ch_blue.s[1] = (float)mix->blue.green_gain; + ch_blue.s[2] = (float)mix->blue.blue_gain; + ch_black.s[0] = (float)mix->black.red_gain; + ch_black.s[1] = (float)mix->black.green_gain; + ch_black.s[2] = (float)mix->black.blue_gain; +
+ if( !cl_data )
+ const char *kernel_name[] = {"cl_channel_mixer", NULL}; + cl_data = gegl_cl_compile_and_build( channel_mixer_cl_source, kernel_name ); + }
+ if( !cl_data )
+ return TRUE;
+ else
+ cl_int cl_err = 0;
+ cl_err = gegl_cl_set_kernel_args(cl_data->kernel[0], + sizeof(cl_mem),(void*)&in_tex, + sizeof(cl_mem),(void*)&out_tex, + sizeof(cl_float4),(void*)&ch_red, + sizeof(cl_float4),(void*)&ch_green, + sizeof(cl_float4),(void*)&ch_blue, + sizeof(cl_float4),(void*)&ch_black, + sizeof(cl_float),(void*)&red_norm, + sizeof(cl_float),(void*)&green_norm, + sizeof(cl_float),(void*)&blue_norm, + sizeof(cl_float),(void*)&black_norm, + sizeof(cl_int),(void*)&mix->monochrome, + sizeof(cl_int),(void*)&mix->has_alpha, NULL); + CL_CHECK;
+ cl_err = gegl_clEnqueueNDRangeKernel(gegl_cl_get_command_queue(), + cl_data->kernel[0], 1, + NULL, global_ws, NULL, + 0, NULL, NULL); + CL_CHECK;
+ return FALSE;
+error:
+ return TRUE;
static void
gegl_chant_class_init (GeglChantClass *klass) {
@@ -285,6 +364,7 @@ gegl_chant_class_init (GeglChantClass *klass) point_filter_class = GEGL_OPERATION_POINT_FILTER_CLASS (klass);
point_filter_class->process = process; + point_filter_class->cl_process = cl_process; operation_class->prepare = prepare; G_OBJECT_CLASS (klass)->finalize = finalize;
1.8.3.2
Victor Oliveira
2014-01-22 19:13:06 UTC (about 11 years ago)
Cool!
Because double-precision is not supported (or very slow) in most GPUs, we try to not use it in our OpenCL code. Maybe this is something we should be more careful though.
Your point that gegl_cl_compile_and_build should have compiler flags is pretty good and I'll work on that.
About your code, no complains except that you could use clamp instead of fmin followed by fmax, but I can do that though.
Victor Oliveira
--- /dev/null
@@ -0,0 +1,40 @@
+ float c = 0.0f;
+ if( monochrome )
+ else
+ if( 4==step )
--- /dev/null
@@ -0,0 +1,41 @@
+#include "opencl/gegl-cl.h" +#include "opencl/channel-mixer.cl.h" +
+static gboolean
+ cl_mem in_tex,
+ cl_mem out_tex,
+ glong samples,
+ if( !cl_data )
+ if( !cl_data )
+ return TRUE;
+ else
+ return FALSE;
+error:
+ return TRUE;
static void
-- 1.8.3.2
_______________________________________________ gegl-developer-list mailing list
List address: gegl-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gegl-developer-list
Daniel Sabo
2014-01-22 20:41:05 UTC (about 11 years ago)
It is also possible to call gegl_cl_has_extension("cl_khr_fp64") to check for double support and then pick which kernal source string to build at runtime. But unless it actually needs a double I would avoid it, double will be slower pretty much everywhere, CPU included. (And if it *does* need double precision you probably shouldn't run the OpenCL version on devices that don't support it.)
Victor Oliveira
2014-01-31 02:53:11 UTC (about 11 years ago)
I tried to run the filter in my nvidia card and it is very slow and crashes sometimes (invalid command queue, i.e. something really bad happened). Besides the fact that the cl_process function should accept a size_t instead of a long, I couldn't find any other problems but the problem persists.
Can you give another look at the patch?
Victor
