Translation helper
Translation helper Joao S. O. Bueno 04 Jan 16:25
Joao S. O. Bueno
2014-01-04 16:25:13 UTC (over 11 years ago)
Translation helper
Hi there -
for whoever translates the manual using a PO editing tool, the XML tags that often appear inside the translation strings are not nice to deal with - as the tags have to be copied verbatim, still, their content has to be translated.
Since the tool I am using for this allows for plug-ins, I created one I can bind to a short cut key and simplifies this work a lot.
I am using "lokalize" as the tool - if anyone is using poedit for the GIMP manual,
I'd suggest giving lokalize a try just due to this script - it is really helping a lot.
Unfortunately, the cross-platform tool "POedit" does not allow for plug-ins.
My script is here: https://github.com/jsbueno/lokalize_xmltools
js ->
