Catalan translations, some questions
Catalan translations, some questions Konfrare Albert 07 Dec 08:53
  Catalan translations, some questions Róman Joost 09 Dec 07:01
   Catalan translations, some questions Joao S. O. Bueno 09 Dec 13:53
    Catalan translations, some questions Konfrare Albert 09 Dec 19:08
Konfrare Albert
2013-12-07 08:53:54 UTC (almost 12 years ago)
Hello everyone,
We (Softcatalà group) are translating Gimp documentation to Catalan. I have two questions:
- How can I build the HTML files (in local) with PO files? - Where must I upload the Catalan image files?
Thanks!
*KONFRARE ALBERT*
La Konfraria de la Vila del Pingüí
de La Palma de Cervelló
www.konfraria.org • @La_Konfraria
Róman Joost
2013-12-09 07:01:42 UTC (almost 12 years ago)
On Sat, Dec 07, 2013 at 09:53:54AM +0100, Konfrare Albert wrote:
Hello everyone,
Cheers for your effort!
Most probably you want to only build your catalan files:
ALL_LINGUAS='ca en' ./autogen.sh --without-gimp make
Create a folder under:
images/ca
and add the images structure similar to other translations.
Let me know if you have additional questions :)
Cheers,
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
Joao S. O. Bueno
2013-12-09 13:53:03 UTC (almost 12 years ago)
Hi Konfrare -
From the answer given, Roman assumed you have cloned the git-repository for gimp-help-2 --
although given the nature of your questions, I believe you are updating the translation using the "danmed lies" gnome l10n infraestructure, which allows for downoading/translating/uploading the PO files without actually having a tree checkout of the project.
If that is the case, please follow the instructions to clone the repository at
https://wiki.gnome.org/Git/Developers And the translator specific hints at:
https://wiki.gnome.org/TranslationProject/GitHowTo
That said, if you can get things to build you not necessarily need commit rights - you can create the images in your filesystem, and make a zipfile or tar.gzip, and upload to gnome l10n - the same place where you upload your po files to - with instructions for the translation team on how to put it on the correct folders in gimp-help-2 for comitting.
Hello everyone,
images/ca
Cheers, --
Roman Joost
_______________________________________________ gimp-docs-list mailing list
gimp-docs-list@gnome.org
Konfrare Albert
2013-12-09 19:08:30 UTC (almost 12 years ago)
I have managed to build the HTML files for Catalan locally. I have downloaded the last package here: ftp://ftp.gimp.org/pub/gimp/help/ $./configure --without-gimp
$sed -e '197cALL_LINGUAS = ca' -e '252cQUICKREFERENCE_ALL_LINGUAS = en' -i Makefile
$make
I have put images in C path (not working in /ca). I have removed the line:
from all HTML files (not working with this, when files are in the server).
This is the result: http://www.konfraria.org/gimp-doc-catalan-testing/ In this site I can upload the last translated strings for team revising.
2013/12/9 Joao S. O. Bueno
Hi Konfrare -
Hello everyone,
images/ca
Cheers, --
Roman Joost
*KONFRARE ALBERT*
