USM update
7 of 7 messages available
USM update Partha Bagchi 07 Dec 00:11
  USM update Elle Stone 07 Dec 00:30
   USM update Partha Bagchi 07 Dec 01:18
    USM update Tobias Ellinghaus 07 Dec 10:04
     USM update Elle Stone 07 Dec 10:58
      USM update Partha Bagchi 07 Dec 16:01
       USM update Partha Bagchi 07 Dec 16:02
Partha Bagchi
2013-12-07 00:11:43 UTC (over 11 years ago)
USM update
Hi Elle,
The recent update to GEGL USM is consistently crashing on Windows (my test machine is Windows 8.1 64-bit).
Thanks, Partha
Elle Stone
2013-12-07 00:30:13 UTC (over 11 years ago)
USM update
On 12/06/2013 07:11 PM, Partha Bagchi wrote:
Hi Elle,
Thanks, Partha
Hi Partha,
I don't have a Windows machine for testing. I suppose it's possible that the ui patch for GEGL USM might cause a crash. Did you try reverting just that one commit?
Here are the last three gegl USM-related commits from "git log" (probably your commit numbers aren't the same as my commit numbers):
commit 1a0e01e9dd3d7f689a75f9f456a2cbd942a46562 Author: Elle Stone
Date: Thu Dec 5 13:54:06 2013 -0500
operations: Change ui slider values for unsharp mask and gaussian blur
commit 773561349e27bb1e0dfa4cbe82a8eb4f1ccd999e Author: To Mazars
Date: Thu Dec 5 19:33:19 2013 +0100
po: forgot to add the new gaussian blur implementation
commit b3557301766d1aa3e3a62859968c3c1b898b7e37 Author: Massimo Valentini
Date: Fri Jul 5 20:32:56 2013 +0200
workshop: add a better gaussian-blur implementation, work in progress
- the fir case is missing for small std-dev - the implementation doesn't allow infinite plane input - the ouptput extent doesn't grow anymore
I can send you a copy of gaussian-blur.c from before the commit, if that would help.
Elle
Partha Bagchi
2013-12-07 01:18:13 UTC (over 11 years ago)
USM update
Thanks! Would you happen to have a copy of unsharp-mask.c from 2 weeks ago? I was not experiencing any crashes with unsharp mask then.
Thanks again, Partha
Hi Elle,
Thanks, Partha
Hi Partha,
Elle
Tobias Ellinghaus
2013-12-07 10:04:15 UTC (over 11 years ago)
USM update
Am Freitag, 6. Dezember 2013, 20:18:13 schrieb Partha Bagchi:
This is the version from before Elle changed it:
https://git.gnome.org/browse/gegl/plain/operations/common/unsharp-mask.c?id=08287da809f1ff41501c331ad18e8c615c395b98
Thanks again,
Partha
Tobias
Elle Stone
2013-12-07 10:58:23 UTC (over 11 years ago)
USM update
Thanks again,
Partha
Tobias
Tobias, Partha, my apologies, it was late and I turned my computer off.
I also substituted "Gaussian Blur" for USM in my mind, totally different things (there's a blur in USM, but that's beside the point).
Anyway, anyone have any ideas why a change in the ui slider values might cause a crash in Windows USM? Could it be because the minimum for the top slider is 0.2 instead of 0.0?
gegl_chant_double_ui (std_dev, _("Std. Dev."), 0.2, 300.0, 0.55, 0.2, 10.0, 3.0, _("Standard deviation (spatial scale factor)"))
gegl_chant_double_ui (scale, _("Scale"), 0.0, 300.0, 4.0, 0.0, 10.0, 3.0, _("Scale, strength of effect"))
Elle, feeling very foolish for having mixed up GB and USM.
Partha Bagchi
2013-12-07 16:01:03 UTC (over 11 years ago)
USM update
Hi Elle,
Not a problem. It's possible the issue is related to gaussian-blur. However, I did try to revert back the latest changes to the unsharp-mask.c from 2 weeks ago and still got the Windows equivalent of segfault. So, I decided to completely start afresh with the a new git pull of babl, gegl and gimp.
I am still getting crashes. The crash is probably related to GSlice:
0x000000006862110F (0x0000000000000001 0x00000001508B82E0 0x00000001508B82F0 0x0000000000339D95), g_slice_free1() + 0x17F bytes(s) 0x0000000000358B1D (0x0000000000000000 0x0000001500000780 0x00006D8EB17BD0C9 0x00000000030EE5A0), g_type_free_instance() + 0x18D bytes(s)
0x00000000618E166E (0x000000000023CA30 0x00000000031B3450 0x0000000000000098 0x000000000035D0D9), gtk_object_destroy() + 0x10E bytes(s)
0x00000000617F966D (0x0000000000000020 0x000000000000008D 0x000000000023CCB0 0x00000000685E6157), gtk_container_unset_focus_chain() + 0x36D bytes(s)
0x0000000000335F6F (0x0000000000000000 0x00000000685E6157 0x00000000030E1830 0x00000000031759D0), g_closure_invoke() + 0x12F bytes(s) 0x00000000003481CD (0x0000000000000000 0x000000000000004A 0x000000003DE44B80 0x0000000000000030), g_signal_handler_disconnect() + 0x198D bytes(s)
I can post the full error set if anyone wishes.
Thanks, Partha
https://git.gnome.org/browse/gegl/plain/operations/common/ unsharp-mask.c?id=08287da809f1ff41501c331ad18e8c615c395b98
Thanks again,
Partha
Tobias
Partha Bagchi
2013-12-07 16:02:13 UTC (over 11 years ago)
USM update
Sorry, that should be "a new git clone" and not "a new git pull".
Thanks, Partha
On Sat, Dec 7, 2013 at 11:01 AM, Partha Bagchi wrote:
Hi Elle,
Thanks, Partha
Thanks again,
Partha
Tobias
