GIMP_DEPRECATED - recipe for translation?
GIMP_DEPRECATED - recipe for translation? Michael Natterer 27 Nov 18:35
Michael Natterer
2013-11-27 18:35:58 UTC (over 11 years ago)
On Wed, 2013-11-27 at 18:17 +0100, Helmut Jarausch wrote:
I have a plugin which uses lots of functions which are deprecated now. Since the macro GIMP_DEPRECATED_FOR suggests functions with totally different parameters
GIMP_DEPRECATED_FOR(gimp_drawable_get_buffer) void gimp_pixel_rgn_init (GimpPixelRgn *pr, GimpDrawable *drawable, gint x, gint y, gint width, gint height, gint dirty, gint shadow);
(gimp_drawable_get_buffer has a single drawable_ID parameter only)
is there a recipe how to translate the old calls into the current function calls?
first of all, there should clearly be a guide for porting GimpDrawable/GimpPixelRgn code to GeglBuffer.
gimp_drawable_get_buffer() or gimp_drawable_get_shadow_buffer() are the right replacement APIs here. What to do further depends on what you do next with the pixel region. Look at the GIMP_DEPRECATED_FOR() above the remaining pixel region functions to figure how to proceed with the buffer.
The GEGL API is documented at http://www.gegl.org/api.html
Maybe you can write up a tutorial about how you ported your plug-in :)
--Mtich
