gimp-developer-list Digest, Vol 26, Issue 10
1 of 2 messages available
mailman.5.1384257602.31278.... 12 Nov 23:32
  gimp-developer-list Digest, Vol 26, Issue 10 Thomas W 12 Nov 23:31
Thomas W
2013-11-12 23:31:39 UTC (about 12 years ago)
Hi DeVont, thanks for your suggestions & interest in contribution.
I'm not really a GIMP developer and am definitely not familiar with the codebase, but I'm deeply familiar with software engineering/ re-engineering & I'll just give you a few comments on first principles.
1. gimp/libgimpmath/gimpmathtypes.h (file in question:gimp/libgimpmath/gimpmatrix.h(c))
This file declares math structures that gimp uses like vectors and matrices. The GimpMatrix structure come in 2X2, 3X3 and even 4X4 versions. Each matrix is a 2Dimensional gdouble array with the appropriate amount of elements to span the NXN matrix.I believe this data structure is used for computation during image editing. There are functions handling comparisons, identities, transformations, rotations, translations and various other matrix operations.
Possible changes: I believe the declaration of 3 special kinds of gimp matrices can be generalized to a struct (or class) that holds and defines an NXN matrix.
Generalizing these structures, would almost certainly make them slower. While in peripheral areas that might be fine, I do not think GIMP users wish to lose performance on matrix-based image transformations.
Neither am I aware that there could ever be a need for matrices larger than 4x4.
So, I probably recommend against pursuing #1.
2. gimp/app/core/gimpcontainer.h
This class contains a data structure that is used to store different
things about the
various objects in gimp. It works hand and hand with the GimpObject class. This class uses what I believe to be some form of tree or heap structure.
The
class refers to add, remove, reorder, and getChild functions that are
defined
across the class. The gimp.h code uses the GimpContainer class pointers
for everything
from fonts, to documents, to displays. As this data structure is used with GimpObject (which controls a large amount of functionality in gimp) and is heavily referenced in the gimp.h file, optimizing this class could go a
long way in
optimizing the code.
This area is probably more productive for investigation. You will need to take some measurements/ benchmarks, to verify whether your changes are delivering an actual performance improvement -- and by how much.
If you document the number of calls into this data structure/site, measure performance beforehand, trial various changes, measure & document performance from each version, write the results up formally and submit code (if any) you will have completed your assignment fully.
I am not assuming that you will be able to improve performance, this may be quite possible but even measuring & investigating thoroughly and coming to the well-supported conclusion that you can't, would be a very competent completion of your assignment.
If we decrease the amount of time to ?reorder? the tree, then we decrease
the amount of time
several other objects take to be initialized and added to the tree.
Well, it sounds quite plausible! But only the measurements can tell.
3. gimp/libgimpmath/gimpvector.h(c) The GimpVector data structure keeps track of axis orientations and
lengths.
I believe this is used in the various drawing tools. I also believe the automated shapes functions may use it for drawing polygons. The vector
data
structure is a structure that holds four gdouble variables that are separately declared (gdouble x, y, z, w for the 4axis vector for example). There are three versions of the gimp vector: 2axis, 3axis, and 4axis. A
potential change to
GimpVector could be altering the way that it is stored like we plan to change the GimpMatrix. This means making a streamlined generalized vector
that can be of
dimension N.
I didn't like the GimpMatrix idea, due to reduced efficiency of very-heavily used code. I expect the GimpVector may also be quite heavily used -- perhaps less so than GimpMatrix, but I would have to be convinced it was not performance-critical.
"Unrolled loops" -- and thus separate size-specific implementations, as per the existing code -- are the best design choice for performance-critical code.
Implementing a variable-length vector/list will, I expect, be vastly slower than using a fixed-size struct or array. Structs and arrays are much more efficient to allocate & de-reference.. Perhaps comparing such codes on a testbed might give you a better idea/assessment of the potential relative performance?
IN CONCLUSION:
It's great that your group is interested & willing to challenge yourself, by taking a look at some serious large-scale software.
I think #2 (GimpContainer/ the heap) sounds like the most plausible area for investigation & optimization. Make sure you measure & benchmark in a reliable way (warm-up first, # of iterations, etc) -- you may need to write some scripts or support code to enable this.
Be sure to write up all your initial measurements, different approaches, results & conclusions.
Good luck!
