params of gegl:transform operation
| params of gegl:transform operation | beee | 29 Sep 10:06 |
| params of gegl:transform operation | Michael Henning | 29 Sep 13:55 |
| params of gegl:transform operation | beee | 08 Oct 06:14 |
| params of gegl:transform operation | Michael Henning | 26 Oct 20:28 |
I want to apply perspective effects on an image. But I can't find an operation for it. I thought maybe I can do it with gegl:transform. But I don't know which parameters should use.
Please help. Thanks!
Regards.
To use gegl:transform, you need to create the transformation matrix yourself. There are plenty of tutorials for learning how to create transformation matrices online.
Then, do this to set the node's property:
1. When you create your matrix, place it in a GeglMatrix3 struct. It
contains one member named coeff, which is a 3x3 array of doubles for
the matrix values.
2. Turn the matrix into a string with gchar* gegl_matrix3_to_string
(GeglMatrix3 *matrix);
3. Set this string as the property "transform" on your gegl:transform
node with gegl_node_set.
4. Free the string from (2) with g_free
Anyway, I hope this helps! Feel free to ask if you have any issues.
-- drawoc
Regards.
_______________________________________________ gegl-developer-list mailing list
List address: gegl-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gegl-developer-list
Dear Michael,
Thanks for your kindly help. I have another question: How can I fill a region with gradient color using gegl?
1. When you create your matrix, place it in a GeglMatrix3 struct. It contains one member named coeff, which is a 3x3 array of doubles for the matrix values.
2. Turn the matrix into a string with gchar* gegl_matrix3_to_string (GeglMatrix3 *matrix);
3. Set this string as the property "transform" on your gegl:transform node with gegl_node_set.
4. Free the string from (2) with g_freeAnyway, I hope this helps! Feel free to ask if you have any issues.
-- drawoc
Regards.
Sorry, I've been busy, and I forgot to reply to this.
Gegl doesn't have any built-in operations for gradients right now, but you can code your own, either as operations, or that operate on gegl buffers.
There are some operations for gradients that are in gegl's source
tree, but they're marked as experimental, and they aren't built by
default. You can build them if you build gegl with --enable-workshop.
Their code is here:
operations/workshop/linear-gradient.c
operations/workshop/radial-gradient.c
I haven't looked at them closely, so I can't vouch for whether their code is correct or not, and when operations are maked experimental like this, there's often something slightly wrong with them. Still, they might be a good starting point.
On Tue, Oct 8, 2013 at 2:14 AM, beee wrote:
Dear Michael,
-- drawoc
Regards.
