Problem with showing EXIF data from NEF figures
On 13-08-16 06:38 AM, Petr Hracek wrote:
I have observed that when I am loading NEF figure into GIMP.
then EXIF data are not visible in Advanced window. (File->Properties->Advanced)
How can I checked whether problem is on UFraw side or in GIMP side.
Any logs for analyse would be appropriated. But how to get those logs?
I have got those logs when GIMP was started from command line:
While parsing XMP metadata:
Error: No XMP packet found
Not implemented yet (EDITOR_PROC)
It is a dcraw issue. (IIRC, UFraw uses dcraw). I use the dcraw plugin as I
didn't like UFraw asking me how it should massage the image before I have
seen it in GIMP.
When I run GIMP via a command line under Linux and ask it to load a NEF file
I see the same error messages from dcraw.
Cheers!
Kevin.
http://www.ve3syb.ca/ |"Nerds make the shiny things that distract
Owner of Elecraft K2 #2172 | the mouth-breathers, and that's why we're
| powerful!"
#include | --Chris Hardwick
