Oversampling with Healing Tool on the edges
Oversampling with Healing Tool on the edges YAFU 08 Aug 19:57
YAFU
2013-08-08 19:57:55 UTC (over 11 years ago)
Hello.
First say, Healing Tool is excellent! I use it a lot and makes the job easy. But I posed the following problem in GimpChat:
http://gimpchat.com/viewtopic.php?f=4&t=8126
As I explained there, is a bit annoying to work on the edges due to what I think, an oversampling (I do not know how to call it exactly). I would like to know if the developers could make Healing Tool is a little smarter when working under conditions explained in the GimpChat thread. Perhaps adding a special option when working near hard edges you do not want to be sampled.
Thank you.
