Need help with Python on GIMP 2.8 for bug fixing
8 of 8 messages available
Need help with Python on GIMP 2.8 for bug fixing bart@neeneenee.de 02 Aug 18:33
  Need help with Python on GIMP 2.8 for bug fixing Ofnuts 02 Aug 19:41
   Need help with Python on GIMP 2.8 for bug fixing Joao S. O. Bueno 02 Aug 20:29
  Need help with Python on GIMP 2.8 for bug fixing bart@neeneenee.de 03 Aug 09:04
   Need help with Python on GIMP 2.8 for bug fixing Ofnuts 03 Aug 10:18
    Need help with Python on GIMP 2.8 for bug fixing bart@neeneenee.de 03 Aug 17:33
     Need help with Python on GIMP 2.8 for bug fixing Michael Schumacher 03 Aug 17:53
      Need help with Python on GIMP 2.8 for bug fixing bart@neeneenee.de 03 Aug 18:19
bart@neeneenee.de
2013-08-02 18:33:11 UTC (over 11 years ago)
Dear GIMP devs,
i'm the author of "CMYK Tiff 2 PDF" which is an addon for GIMP and the Seperate+ plugin.
My script is part of the plugin registry too.
But it seems it doesn't show up in GIMP 2.8./ Ubuntu.
I changed the pythin script registration to:
register( "python-fu-cmyk-tiff-2-pdf",
"CMYK Tiff 2 PDF",
"CMYK Tiff 2 PDF 20130802\nCreating a CMYK PDF for prepress from a CMYK Tiff image.",
"Eckhard M. Jaeger, http://my.opera.com/area42/blog/", "GPL V2 License",
"2013",
(PF_FILENAME, "this_file1", _("CMYK Tiff Images"), ""), (PF_FILENAME, "this_file2", _(" "), ""), (PF_RADIO, "this_compress", _("Compression"), "0", (("JPEG 95% Quality","0"), ("Zip Full Quality","2"), ("No Compression","4"))), (PF_SPINNER, "this_dpi", _("Resolution (dpi)"), 300, (0,2400,50)), (PF_TOGGLE, "delete_files", _("Delete Images\nafter PDF creation"), False), (PF_TOGGLE, "start_viewer", _("Start PDF Viewer\nafter export"), True), ],
python_fu_cmyk_tiff_2_pdf,
domain=("gimp20-python", gimp.locale_directory), menu="/Image/Separate/"
main()
But i didn't get it running.
Any help or idea?
2013-08-02 19:41:36 UTC (over 11 years ago)
On 08/02/2013 08:33 PM, bart@neeneenee.de wrote:
Dear GIMP devs,
"CMYK Tiff 2 PDF",
"2013",
main()
Any help or idea?
File "/home/me/.gimp-2.8/plug-ins/testreg.py", line 17, in (PF_FILENAME, "this_file1", _("CMYK Tiff Images"), ""), NameError: name '_' is not defined
Joao S. O. Bueno
2013-08-02 20:29:43 UTC (over 11 years ago)
teh "_" is a call to be used when your plug-in is written with multi-lingual support - either
write your plug-in copying the "_" related bits from another python plug-in with localisation, or leave it apart for now - just put on the beggining files of your plug-in something along:
_ = lambda x: x
This will give you a mockup translating function that will allow you to focus first on the development, and you can polish it to get i18n working later on.
js
Dear GIMP devs,
"CMYK Tiff 2 PDF",
"2013",
main()
Any help or idea?
bart@neeneenee.de
2013-08-03 09:04:49 UTC (over 11 years ago)
Hi all,
thanks for the first hints but no way to get it working. My plugin structure for testing is:
from gimpfu import * import os, string, sys import os.path gettext.install("gimp20-python", gimp.locale_directory, unicode=True) def python_fu_cmyk_tiff_2_pdf(active_image, active_layer, this_file1, this_file2, this_compress, this_dpi, delete_files, start_viewer): do_delete = 0 register( "python_fu_cmyk_tiff_2_pdf", "CMYK Tiff 2 PDF", "CMYK Tiff 2 PDF 20130802\nCreating a CMYK PDF for prepress from a CMYK Tiff image.", "Eckhard M. Jaeger, http://my.opera.com/area42/blog/", "GPL V2 License", "2013", "*", "*", [ (PF_FILENAME, "this_file1", ("CMYK Tiff Images"), ""), (PF_FILENAME, "this_file2", (" "), ""), (PF_RADIO, "this_compress", ("Compression"), "0", (("JPEG 95% Quality","0"), ("Zip Full Quality","2"), ("No Compression","4"))), (PF_SPINNER, "this_dpi", ("Resolution (dpi)"), 300, (0,2400,50)), (PF_TOGGLE, "delete_files", ("Delete Images\nafter PDF creation"), False), (PF_TOGGLE, "start_viewer", ("Start PDF Viewer\nafter export"), True), ], [], python_fu_cmyk_tiff_2_pdf, domain=("gimp20-python", gimp.locale_directory), menu="/Image/Separate/" ) main() I didn't get an eror on the python console nor the plugin showed up at menus or python script listing :( Cheers Eckhard.
2013-08-03 10:18:44 UTC (over 11 years ago)
On 08/03/2013 11:04 AM, bart@neeneenee.de wrote:
Hi all,
get an eror on the python console nor the plugin showed up at menus or python script listing :( Cheers Eckhard. _______________________________________________
No way python is going to run this jumbled code...
You seem to be missing at least one "import gettext"...
PM me the full thing otherwise...
bart@neeneenee.de
2013-08-03 17:33:50 UTC (over 11 years ago)
Hi all,
thanks for all your help, at least it was very easy get it running. It seems that in GIMP 2.8.x Python script will initialized if they are located at the "plug-ins" directory and not at the "scripts" directory.
Seems the "gimp-plugin-registry" package made this error.
Best regards Eckhard.
BTW: There is no up-to-date documentation about Python in GIMP 2.8 right?
Hi all,
from gimpfu import * import os, string, sys import os.path gettext.install("gimp20-python", gimp.locale_directory, unicode=True) def python_fu_cmyk_tiff_2_pdf(active_image, active_layer, this_file1, this_file2, this_compress, this_dpi, delete_files, start_viewer): do_delete = 0 register( "python_fu_cmyk_tiff_2_pdf", "CMYK Tiff 2 PDF", "CMYK Tiff 2 PDF 20130802\nCreating a CMYK PDF for prepress from a CMYK Tiff image.", "Eckhard M. Jaeger, http://my.opera.com/area42/blog/", "GPL V2 License", "2013", "*", "*", [ (PF_FILENAME, "this_file1", ("CMYK Tiff Images"), ""), (PF_FILENAME, "this_file2", (" "), ""), (PF_RADIO, "this_compress", ("Compression"), "0", (("JPEG 95% Quality","0"), ("Zip Full Quality","2"), ("No Compression","4"))), (PF_SPINNER, "this_dpi", ("Resolution (dpi)"), 300, (0,2400,50)), (PF_TOGGLE, "delete_files", ("Delete Images\nafter PDF creation"), False), (PF_TOGGLE, "start_viewer", ("Start PDF Viewer\nafter export"), True), ], [], python_fu_cmyk_tiff_2_pdf, domain=("gimp20-python", gimp.locale_directory), menu="/Image/Separate/" ) main() I didn't get an eror on the python console nor the plugin showed up at menus or python script listing :( Cheers Eckhard. _______________________________________________
2013-08-03 17:53:53 UTC (over 11 years ago)
On 03.08.2013 19:33, bart@neeneenee.de wrote:
Hi all,
They were always supposed to be there, previous versions of GIMP are no different in that regard.
bart@neeneenee.de
2013-08-03 18:19:33 UTC (over 11 years ago)
Hi Michael,
i droped a line to the package maintainer of the Debian package "gimp-plugin-registry" to fix it.
Hi all,
