Gimp git error?
Gimp git error? | Partha Bagchi | 02 Aug 13:51 |
Gimp git error? | scl | 03 Aug 10:02 |
Gimp git error? | Partha Bagchi | 03 Aug 11:12 |
Gimp git error? | Michael Henning | 03 Aug 17:52 |
Gimp git error? | su_v | 03 Aug 19:36 |
Gimp git error? | Partha Bagchi | 03 Aug 22:00 |
Gimp git error? | Michael Henning | 04 Aug 16:32 |
Gimp git error? | Partha Bagchi | 04 Aug 17:18 |
Gimp git error? | Michael Henning | 04 Aug 17:20 |
Gimp git error? | Michael Henning | 04 Aug 17:37 |
Gimp git error? | Partha Bagchi | 04 Aug 18:13 |
Gimp git error? | Partha Bagchi | 04 Aug 22:05 |
Gimp git error? | Michael Henning | 05 Aug 02:27 |
Gimp git error?
Just started getting this message this morning (all git pulls up to date):
GEGL operation missing!
GIMP requires the GEGL operation "gegl:seamless-clone". This operation cannot be found. Check your GEGL install and ensure it has been compiled with any dependencies required for GIMP.
Log says: (process:59616): GLib-GObject-WARNING **: plugin pointer (0x104809010) for type 'GeglChantseamless-clone_c' is invalid
Running on a Macbook Pro - Mountain Lion.
Thanks, Partha
Gimp git error?
GIMP master with Seamless Clone requires GEGL master. Could it be you used GEGLs gegl-0-2 branch?
Kind regards,
Gimp git error?
No.
Kind regards,
______________________________**_________________ gimp-developer-list mailing list
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/**mailman/listinfo/gimp-** developer-list
Gimp git error?
The change in the gimp that caused this is that we now check to make sure you have certain required gegl ops installed. We did not do this until recently, so it's possible the seamless clone op was broken on your machine for a while, and we just caught it.
I don't really know why your seamless clone op is broken. That error message on the console it too generic.
If I were you, I would try wiping my prefix, running git clean, and then recompiling. If that doesn't help, then we need to do some debugging.
Does anyone else with a mac build from git get the same error message?
On Sat, Aug 3, 2013 at 7:12 AM, Partha Bagchi wrote:
No.
Kind regards,
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/**mailman/listinfo/gimp-** developer-list_______________________________________________ gimp-developer-list mailing list
Gimp git error?
On OS X 10.7.5, with dependencies installed via MacPorts (including gegl from git master with custom portfile), I don't see the error messages about the missing GEGL operation ("gegl:seamless-clone"):
Tested earlier with - gegl @ 23646ab71548b9b706e8712e03e3e375db541170 - GIMP @ 96a090d9b12d20deec20248a841f7b36e103c17c
and with just updated latest builds: - gegl @ 3949fa1bd5936d6c72d6fa8343c5a3a790625ca0 - GIMP @ 56f065321ce42f907879dfa4a76e57de18b058eb
Tests have been done in two separate build envs (GTK+/Quartz, GTK+/X11).
No.
Kind regards,
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-developer-list_______________________________________________ gimp-developer-list mailing list
Gimp git error?
Well, I build babl/gegl/gimp simultaneously and so they are all update. Just to rule out that it's an issue on my side, I completey wiped out both gegl and gimp and recloned them. Then I rebuilt the app. So, not sure the issue is on my side. Also, gdb cannot debug since gimp quits prior to starting.
How do we disable seamless clone if necessary? Is it even necessary?
Thanks, Partha
No.
date):
Kind regards,
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/**mailman/listinfo/gimp-** developer-list<https://mail.gnome.org/mailman/listinfo/gimp-developer-list>
Gimp git error?
Well, you could open up app/sanity.c and comment out the line that says "gegl:seamless-clone", to disable the check, although then you'll have a broken seamless clone tool.
It seems like the proper fix would be to try and make the seamless clone op work on your computer. The error happens during loading, so you'd need to run gimp from within gdb. It might help if you place a breakpoint on g_warning and get a full trace (with variables) of that when it breaks.
Thanks, Partha
No.
Kind regards,
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/**mailman/listinfo/gimp-**developer-list
Gimp git error?
OK, Thanks for the work around. As I said, I am not sure if seamless clone is needed anyway.
As for running gimp through gdb, it's not possible not since gimp does not even start.
Here is what I get:
----------------------------gdb output------------------------------------
gdb ./gimp-2.9
GNU gdb 6.3.50-20050815 (Apple version gdb-1515) (Sat Jan 15 08:33:48 UTC
2011)
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "x86_64-apple-darwin"...Reading symbols for
shared libraries ...................................... done
(gdb) r
Starting program:
/Users/partha/projects/src/gimp/Gimp-2.9.app/Contents/MacOS/gimp-2.9
Reading symbols for shared libraries
done
Reading symbols for shared libraries . done
....... (more of the same)
Reading symbols for shared libraries .......... done
(process:86287): GLib-GObject-WARNING **: invalid cast from '(null)' to 'GTypePlugin'
(process:86287): GLib-GObject-WARNING **: plugin pointer (0x10400df00) for type 'GeglChantseamless-clone-compose_c' is invalid Reading symbols for shared libraries .......... done
(process:86287): GLib-GObject-WARNING **: plugin pointer (0x102043010) for
(throws up the dialogbox I mentioned before and then)
Program exited with code 01.
(gdb)
(gdb)
Just
gegl
issue
Thanks, Partha
On Sat, Aug 3, 2013 at 1:52 PM, Michael Henning <
wrote:
No.
Kind regards,
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/**mailman/listinfo/gimp-**developer-list<
Gimp git error?
Quick correction: put the breakpoint on g_log, not g_warning. g_warning is actually a #define.
Thanks, Partha
No.
Kind regards,
Gimp git error?
Let me clarify. After you start gdb, but before starting GIMP, type:
break g_log
set logging on
run
Then, whenever gdb stops the program (may happen a few times), type:
bt full continue
Once the dialog box appears, close it and you're done. Then, find gdb.txt and attach it here or put it on a pastebin.
Thanks.
Thanks, Partha
No.
Kind regards,
Gimp git error?
Michael,
Sorry to be dense. But gimp stops running after you click OK on the dialog box and the gdb stack is empty. So, I am not sure what you are expecting in the logfile? gdb.txt shows exactly what I posted above.
2011)
conditions.
(gdb) break g_log
Breakpoint 1 at 0x22d0e560408c1e0
(gdb) set logging on
Copying output to gdb.txt.
(gdb) run
done
---Type to continue, or q to quit---
(After a couple of these screens I get:
(process:86394): GLib-GObject-WARNING **: invalid cast from '(null)' to 'GTypePlugin'
(process:86394): GLib-GObject-WARNING **: plugin pointer (0x10480df00) for type 'GeglChantseamless-clone-compose_c' is invalid Reading symbols for shared libraries .......... done
(process:86394): GLib-GObject-WARNING **: plugin pointer (0x10206b010) for type 'GeglChantseamless-clone_c' is invalid Reading symbols for shared libraries . done Reading symbols for shared libraries . done
After a couple of more screens, the dialog box appears:
When you press OK, you get:
(gdb) bt full
No stack.
(gdb)
gdb.txt just contains the above other than a warning about liblzma.5.dylib which I know about.
Thanks,
Partha
break g_log set logging on
runThen, whenever gdb stops the program (may happen a few times), type:
bt full continue
Thanks.
update. Just
gegl
issue
starting.
Thanks, Partha
wrote:
No.
to
date):
Kind regards,
Gimp git error?
Michael,
Additional information: After I commented out seamless clone from sanity check, Gimp compiled and ran fine.
I tried out "LightiningIsMyName"'s youtube video and it works on the Mac fine without the need for this check. Of course, it's excruciatingly slow and takes forever on my speedy Mac for even a 10 MP image.
Thanks, Partha
On Sun, Aug 4, 2013 at 2:13 PM, Partha Bagchi wrote:
Michael,
NU gdb 6.3.50-20050815 (Apple version gdb-1515) (Sat Jan 15 08:33:48 UTC 2011)
Copyright 2004 Free Software Foundation, Inc. GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions. There is absolutely no warranty for GDB. Type "show warranty" for details. This GDB was configured as "x86_64-apple-darwin"...Reading symbols for shared libraries ...................................... done(gdb) break g_log Breakpoint 1 at 0x22d0e560408c1e0
(gdb) run
Reading symbols for shared libraries +++++++++++++++++.+++++++++++++++++++........................................................................................................................................................ done
Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done Reading symbols for shared libraries . done ---Type to continue, or q to quit--- (After a couple of these screens I get: Reading symbols for shared libraries .......... done(process:86394): GLib-GObject-WARNING **: invalid cast from '(null)' to 'GTypePlugin'
Program exited with code 01. (gdb) bt full
No stack.
(gdb)gdb.txt just contains the above other than a warning about liblzma.5.dylib which I know about.
Thanks,
ParthaOn Sun, Aug 4, 2013 at 1:37 PM, Michael Henning
bt full continue
Thanks.
update. Just
gegl
issue
starting.
Thanks, Partha
message?
wrote:
No.
to
date):
Kind regards,
List address: gimp-developer-list@gnome.org List membership:https://mail.gnome.org/**mailman/listinfo/gimp-**
developer-list<
Gimp git error?
I forgot: for the instructions in my last email to work, you probably need to compile glib with debugging symbols.
On Sun, Aug 4, 2013 at 6:05 PM, Partha Bagchi wrote:
Michael,
Thanks, Partha
Michael,
(gdb) run
No stack.
Thanks,
bt full continue
Thanks.
is on my side. Also, gdb cannot debug since gimp quits prior to starting.How do we disable seamless clone if necessary? Is it even necessary?
Thanks, Partha
until recently, so it's possible the seamless clone op was broken on your machine for a while, and we just caught it.I don't really know why your seamless clone op is broken. That error message on the console it too generic.
No.
date):GEGL operation missing!
Kind regards,
