Suggestion
Suggestion Ellis Hoeffler 11 Jul 17:19
  Suggestion Alexandre Prokoudine 12 Jul 12:25
  Suggestion Pat David 12 Jul 14:05
Ellis Hoeffler
2013-07-11 17:19:23 UTC (almost 12 years ago)
Suggestion
I could not find out where I could actually post a suggestion for a feature. can you give me the link. Also the feature that I wanted to suggest is a button or tool that makes any pasted image the same color as the one underneath. for example when I have a picture of a person and I want to edit that persons head onto another body it would change the head color to be the same as the other one if the colors are diffrent in any way. Like if the pasted head is pinkish and the original head is tanish orange it would change the pasted head the same shade of tanish orange as the other head.
Thanks for your time!
2013-07-12 12:25:18 UTC (almost 12 years ago)
Suggestion
You are already here. We prefer to discuss feature requests in this mailing list :)
This is exactly what a new Seamless Paste tool does. Unfortunately it isn't complete yet (has bugs, works too slowly). So it's on radar, we just don't know when it will be ready for wide use.
Pat David
2013-07-12 14:05:49 UTC (almost 12 years ago)
Suggestion
I believe Alexandre already mentioned seamless paste. For now you could also do it manually, and use it as a learning tool by using sample points and curves. Not to be spammy, but I had written a tutorial for doing this manually here:
http://blog.patdavid.net/2012/07/getting-around-in-gimp-more-color.html. There's a lot of power just in those two features...
pat david
