Paths need better display of on-canvas transform tools
Paths need better display of on-canvas transform tools Richard Gitschlag 26 Jun 15:28
  Paths need better display of on-canvas transform tools Ofnuts 28 Jun 07:08
   Paths need better display of on-canvas transform tools Richard Gitschlag 28 Jun 13:57
Richard Gitschlag
2013-06-26 15:28:21 UTC (over 12 years ago)
I was using the Perspective Distortion on a path-from-text the other day when I noticed a usability gripe: The tool's on-canvas preview (i.e. the transformation handles and guides) used the entire image canvas size. Although it did display an on-canvas preview of the path being transformed, the particular skew I was looking for required stretching the transformation handles well outside the bounds of the image canvas -- not exactly convenient when the path in question occupies a relatively small portion of the entire image canvas.
For comparison, when you use a transform tool on a layer, GIMP uses the bounds of that layer for the preview grid (if a selection is present, GIMP also limits it to the layer's selected area). Likewise, if you use a transformation tool on the selection mask itself, GIMP also uses the rectangular bounds of that selection.
But when you use a transform tool on a path, GIMP should grab the rectangular bounds of the path you are modifying and base its preview (transformation handles and guides) on that. Much more intuitive that it's modifying a path, not the whole image.
2013-06-28 07:08:53 UTC (over 12 years ago)
If you have a selection the transform tool handles are on the boundaries of the selection... (the tool will still apply to the whole path)
http://i.imgur.com/ApvhjV0.png
Richard Gitschlag
2013-06-28 13:57:55 UTC (over 12 years ago)
Date: Fri, 28 Jun 2013 09:08:53 +0200 From: ofnuts@laposte.net
Subject: Re: [Gimp-developer] Paths need better display of on-canvas transform tools
A workaround, I know. It's just that the transform tool handles need to reflect the item that is actually being affected -- they already do that if it's the current layer (or selected portion of a layer) or selection mask itself. Paths just need to follow suit.
