"checking for BZ2_bzCompress in -lbz2... no"
"checking for BZ2_bzCompress in -lbz2... no" fabrixx 25 Jun 22:34
  "checking for BZ2_bzCompress in -lbz2... no" Partha Bagchi 25 Jun 23:36
   "checking for BZ2_bzCompress in -lbz2... no" fabrixx 26 Jun 17:01
2013-06-25 22:34:51 UTC (almost 12 years ago)
I'm tryng to compile gimp into my Debian.
I have the package libbz2-1.0 and linked related library files it from /lib/lib64xxx to /usr/lib & ldconfig but config say me same error:
I also tryed to copy the libs in gimp source folder with no results.
How to fix?
Partha Bagchi
2013-06-25 23:36:58 UTC (almost 12 years ago)
Don't copy system files to the tree!
In the tree, do the following: grep -i bz2 config.log -n -a10
Basically check the log to see why conftest.c is failing at bz2. That should tell you why BZ2_bzCompress is missing.
My guess is you are missing the libbz2-1.0.dev (or whatever it's called in Debian). Pull in the dev package using your package installer.
How to fix?
-- fabrixx (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
2013-06-26 17:01:31 UTC (almost 12 years ago)
Ok was the dev package, my error, excuse me...
