bump-map operation
bump-map operation Dov Grobgeld 25 Jun 20:05
  bump-map operation Michael Natterer 25 Jun 22:30
   bump-map operation Dov Grobgeld 26 Jun 09:05
    bump-map operation Michael Natterer 26 Jun 17:01
Dov Grobgeld
2013-06-25 20:05:21 UTC (over 12 years ago)
bump-map operation
I just added a bump-map operation. It is heavily based on the corresponding gimp code, but modified according to my understanding of gegl. The fact that the bumpmap is in floating point makes the resulting "surface" much smoother than the original gimp operation, as 8-bit is too little to get accurate surface normals.
Please let me know your comments about the code and update wiki "Hacking:Porting filters to GEGL" page. (I would have done it myself if the maintainer of the wiki would have answered my email requesting write access.)
Dov
Michael Natterer
2013-06-25 22:30:36 UTC (over 12 years ago)
bump-map operation
Thanks Dov, that's cool :)
I pushed a small whitespace cleanup to bump-map.c, and the last parameter of the chanted properties is supposed to be a human readable blurb that appears as tooltip in GIMP, so should be human readable :)
Also, does the op really need the entire input? Can't it be done like an area filter? Requiring the entire input makes it impossible to adjust parameters interactively in GIMP's GEGL tool.
Regards, --Mitch
Dov Grobgeld
2013-06-26 09:05:30 UTC (over 12 years ago)
bump-map operation
The filter certainly is local as it is only using a 3×3 neighborhood. What example op can I look at in order to see exactly what requirements I need to fulfill to make the op into an "area filter" and make it work with Gimp's GEGL tool? Is this documented anywhere?
I thought about looking at the NewsPrint plugin next. Or is there some other plugin that is more urgent?
Regards, Dov
Regards, --Mitch
Michael Natterer
2013-06-26 17:01:52 UTC (over 12 years ago)
bump-map operation
I'm not the über-expert myself, but look at the last two functions in gegl-operation-area-filter.c, I think that's all you need to implement in bump-map.
That plug-in has a very complex GUI and we have no way just yet to easily do that with the GEGL tool (with on-canvas preview), also it's rather esoteric so it probably falls in the category "port the GIMP plug-in to the new GeglBuffer API in libgimp and done".
My personal favorite is the mosaic plugin because I really like the effect. That doesn't make it "urgent" tho ;) (If you really want to do that, there is a patch in bugzilla that adds a configurable random seed to the GIMP plugin, maybe the port should be done from a version that includes that patch).
IMO dilate and erode are in the "must have" section for commonly known generic operations that are missing.
Opinions from anyone?
Regards, --Mitch
Dov
Regards, --Mitch
