Help building help.
23 of 23 messages available
Help building help. john Culleton 11 Jun 18:41
  Help building help. Ulf-D. Ehlert 12 Jun 20:17
   Help building help. Marco Ciampa 13 Jun 08:00
    Help building help. Roman Joost 26 Jun 06:14
     Help building help. Marco Ciampa 26 Jun 12:58
     Help building help. Alexandre Prokoudine 26 Jun 13:04
      Help building help. Roman Joost 01 Jul 07:36
       Help building help. Marco Ciampa 21 Jul 00:57
  Help building help. Marco Ciampa 21 Jul 01:13
   Help building help. Jihui Choi 18 Aug 12:19
   Help building help. Marco Ciampa 18 Aug 14:02
    Help building help. Marco Ciampa 18 Aug 14:32
     Help building help. Jihui Choi 18 Aug 15:43
      Help building help. Marco Ciampa 19 Aug 09:04
       Help building help. Jihui Choi 19 Aug 10:01
        GIMP doc on Cygwin Kolbjørn Stuestøl 07 Sep 12:15
         GIMP doc on Cygwin Marco Ciampa 07 Sep 17:04
          GIMP doc on Cygwin Kolbjørn Stuestøl 08 Sep 08:49
         GIMP doc on Cygwin Julien Hardelin 10 Sep 19:30
          GIMP doc on Cygwin Kolbjørn Stuestøl 10 Sep 21:25
           Updating quickreference Kolbjørn Stuestøl 10 Sep 22:13
            Updating quickreference Alexandre Prokoudine 11 Sep 04:11
             Updating quickreference Kolbjørn Stuestøl 11 Sep 17:04
john Culleton
2013-06-11 18:41:02 UTC (almost 12 years ago)
Help building help.
Elaborate things break more often then simple things. All I want is a Gimp Manual in pdf form for version 2.8. I can print this out, put it in a ring binder and use it as needed. What I got instead was a package with the guts of the manual in xml. I tried autogen, then ./configure, and then make. Consistently I get these error messages:
Making all in quickreference make[1]: Entering directory
`/home/safe/Documents/gimp-help-2.8.0/quickreference' make[1]: *** No rule to make target `svg/gimp-keys-ca.svg', needed by `svg'. Stop. make[1]: Leaving directory
`/home/safe/Documents/gimp-help-2.8.0/quickreference' make: *** [all-recursive] Error 1
Before I start hacking around eliminating references to the quickreference is there a standard solution to my problem?
I don't want to spend days learning about docbook, wonderful though it may be. I have a project under way and I need to look some things in the manual.
Anyone have a copy they are willing to share? Slackware 14 if anyone cares.
John Culleton
Wexford Press
Free list of books for self-publishers:
http://wexfordpress.net/shortlist.html
PDF e-book: "Create Book Covers with Scribus"
available at http://www.booklocker.com/books/4055.html
Ulf-D. Ehlert
2013-06-12 20:17:50 UTC (almost 12 years ago)
Help building help.
Making pdf always was problematic for some languages, the html manual is IMO a better choice. BTW, do you really want to print some hundred pages?
A "package" means you didn't pull the current version from the git repository?
You must try
make pdf-en # "en" for the English version
since pdf is not built by default. (And making pdf does not require the quickreference.)
If I remember correctly, this was a bug which has been fixed in the current version from the git repo.
What's wrong with the online manual? ;)
Ulf
Ob selbst das schnste Buch den
Wald aufwiegt, der dafr stirbt?
		-- Karlheinz Deschner
Marco Ciampa
2013-06-13 08:00:12 UTC (almost 12 years ago)
Help building help.
PDF pages are no longer just for print but a mean to read with computer / tablet / ebook reader. I myself use a kindle to read GIMP books in PDF in the spare time.
I would not underestimate the importance of the pdf format for a manual.
Yes I know of may Mac users of GIMP that use updated tar packages of the manual that I feed them sporadically...
You must try
That you have to be on line...
Ulf
_______________________________________________ gimp-docs-list mailing list
gimp-docs-list@gnome.org
Marco Ciampa
| Linux User  #78271 |
| FSFE fellow   #364 |
Roman Joost
2013-06-26 06:14:42 UTC (almost 12 years ago)
Help building help.
Perhaps it would make better sense, to remove the PDF functionality (based on dblatex), since it never left a stable stage.
The reason to choose dblatex was that FOP at the time was not mature enough to produce good quality output. I think that has changed. DbLatex worked well for latin content, but always seemed to give us headaches with totally different character sets. Perhaps it's not dblatex fault, just the lack investigating a good LaTeX -> PDF solution.
Anyhow, perhaps it makes more sense to move to a epub/Kindle solution. I can relate to Marco here, since I'm also using my Kindle to read most of my books now. The Kindle format is even simiar to HTML. Not sure if there are already packages out there who go from DocBook to Kindle/epub.
Cheers
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
Marco Ciampa
2013-06-26 12:58:46 UTC (almost 12 years ago)
Help building help.
There are powerful converters out there. See for example the Git book that is written in markdown and the pandoc suite or Calibre.
References:
http://git-scm.herokuapp.com/book http://git-scm.herokuapp.com/blog/2009/07/28/the-gory-details.html http://www.slideshare.net/larrycai/write-book-in-markdown http://johnmacfarlane.net/pandoc/epub.html http://www.codinghorror.com/blog/2012/10/the-future-of-markdown.html https://github.com/LaPingvino/markdown-example-book http://calibre-ebook.com/
bye
Marco Ciampa
| Linux User  #78271 |
| FSFE fellow   #364 |
2013-06-26 13:04:10 UTC (almost 12 years ago)
Help building help.
http://sourceforge.net/projects/docbook/files/epub3/
However, note that eInk readers are, in my experience, quite inferior for technical reading. Anything that involves tables and color images is likely to make your head hurt :) OTOH, EPU is more than just for eInk readers. Tablets are OK :)
Roman Joost
2013-07-01 07:36:50 UTC (almost 12 years ago)
Help building help.
Hm... sounds like we need a plan. Perhaps I'll create a bug in Bugzilla and we move the discussion there ...
Kind Regards,
Roman Joost
Marco Ciampa
2013-07-21 00:57:13 UTC (almost 12 years ago)
Help building help.
Would you please post here the bug id when you have done?
Thanks!
Marco Ciampa
| Linux User  #78271 |
| FSFE fellow   #364 |
Marco Ciampa
2013-07-21 01:13:30 UTC (almost 12 years ago)
Help building help.
I have another error:
$make pdf-it *** Making PDF (it) ...
Build the book set list...
xsltproc -o /tmp/tmpxAwlqk/doclist.txt --xinclude --xincludestyle doclist.xsl /home/marco/git-gnome/gimp-help-2/xml/it/gimp.xml Build the listings...
xsltproc -o /tmp/tmpxAwlqk/listings.xml --xinclude --xincludestyle --param current.dir '/home/marco/git-gnome/gimp-help-2/xml/it' /usr/share/dblatex/xsl/common/mklistings.xsl /home/marco/git-gnome/gimp-help-2/xml/it/gimp.xml xsltproc -o gimp.rtex --xinclude --xincludestyle --param current.dir '/home/marco/git-gnome/gimp-help-2/xml/it' --param listings.xml '/tmp/tmpxAwlqk/listings.xml' /tmp/tmpxAwlqk/custom.xsl /home/marco/git-gnome/gimp-help-2/xml/it/gimp.xml XSLT stylesheets DocBook - LaTeX 2e (0.3.4-3) =================================================== literal: default template used in programlisting or screen literal: default template used in programlisting or screen Don't know what gentext to create for xref to: "para" (linkend=text-to-path) Don't know what gentext to create for xref to: "para" (linkend=text-along-path) Image 'images/toolbox/paths-transform-1.png' not found Image 'images/toolbox/paths-transform-2.png' not found Image '../images/tool-options/stock-gravity-east-24.png' not found Build gimp.pdf
built-in module xetex registered
no support found for ifthen
no support found for ifxetex
no support found for fontspec
no support found for xltxtra
no support found for fontenc
no support found for ucs
no support found for inputenc
no support found for fancybox
built-in module makeidx registered
no support found for babel
no support found for cmap
no support found for db2latex
built-in module bibtopic registered
building additional files...
checking if compiling is necessary... the output file doesn't exist
xelatex -interaction=batchmode gimp.tex
A possible reason for transformation failure is invalid DocBook (as reported by xmllint)
Error: [Errno 2] No such file or directory make: *** [pdf/it/gimp.pdf] Errore 1
but log/it-xmllint.log
contains
it: no errors.
Any hint?
Marco Ciampa
| Linux User  #78271 |
| FSFE fellow   #364 |
Jihui Choi
2013-08-18 12:19:20 UTC (over 11 years ago)
Help building help.
Hi, Marco.
Is any advance?
Recently I tried to make pdf file, for test, pdf-en. I met above same errors.
If you have any, please let me know.
P.S Some people-especially old people- prefer hard copies, like a book. For that pdf version is very good solution. Of course pdf is great for e-book reader for tablet or smartphone. Unfortunately we've had lots of problems with CJK languages. Thus I almost give it up but if it's possible to make gimp-help-2 to a pdf file, it would be wonderful.
-- Regards,
Jihui Choi
contains
it: no errors.
Any hint?
Marco Ciampa
+--------------------+ | Linux User #78271 |
| FSFE fellow #364 |
Marco Ciampa
2013-08-18 14:02:46 UTC (over 11 years ago)
Help building help.
contains
it: no errors.
Any hint?
xelatex was not installed but autoconf did not signal the problem ... anyway... to me...
make pdf-it
no new compilation is needed running last-compilation scripts...
Character U+E0 (à) not in font 'cmmi10' Character U+2CB (ˋ) not in font 'URW Palladio L Bold/ICU:mapping=tex-text;' Character U+2CB (ˋ) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+3B1 (α) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+2245 (≅) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+592A (太) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+5CF6 (島) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+672C (本) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+6768 (杨) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+7EA2 (红) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+826F (良) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+828A (芊) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+8521 (蔡) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+C9C0 (지) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+CD5C (최) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D76C (희) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' 'gimp.pdf' successfully built
works ;-)
Marco Ciampa
| Linux User  #78271 |
| FSFE fellow   #364 |
Marco Ciampa
2013-08-18 14:32:05 UTC (over 11 years ago)
Help building help.
On Sun, Aug 18, 2013 at 04:02:46PM +0200, Marco Ciampa wrote: [...]
make pdf-it
works ;-)
and even ...
make pdf-ko
Character U+D6C4 (후) not in font 'FreeSans/ICU:script=latn;language=DFLT;mapping=tex-text;' Character U+D6C4 (후) not in font 'URW Palladio L Italic/ICU:mapping=tex-text;' Character U+D6C4 (후) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D6CC (훌) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D6E8 (훨) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D718 (휘) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D71C (휜) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D720 (휠) not in font 'URW Palladio L Bold/ICU:mapping=tex-text;' Character U+D720 (휠) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D734 (휴) not in font 'URW Palladio L Bold/ICU:mapping=tex-text;' Character U+D734 (휴) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D749 (흉) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D750 (흐) not in font 'URW Palladio L Bold/ICU:mapping=tex-text;' Character U+D750 (흐) not in font 'URW Palladio L Italic/ICU:mapping=tex-text;' Character U+D750 (흐) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D751 (흑) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D754 (흔) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D761 (흡) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D765 (흥) not in font 'FreeSans/ICU:script=latn;language=DFLT;mapping=tex-text;' Character U+D765 (흥) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D769 (흩) not in font 'URW Palladio L Italic/ICU:mapping=tex-text;' Character U+D76C (희) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D770 (흰) not in font 'URW Palladio L Italic/ICU:mapping=tex-text;' Character U+D770 (흰) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D788 (히) not in font 'FreeSans/ICU:script=latn;language=DFLT;mapping=tex-text;' Character U+D788 (히) not in font 'URW Palladio L Italic/ICU:mapping=tex-text;' Character U+D788 (히) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D78C (힌) not in font 'URW Palladio L Italic/ICU:mapping=tex-text;' Character U+D78C (힌) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D790 (힐) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D798 (힘) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' Character U+D799 (힙) not in font 'URW Palladio L Roman/ICU:mapping=tex-text;' 'gimp.pdf' successfully built
... to you works! ;-)
If you like I can send you a copy...
Marco Ciampa
| Linux User  #78271 |
| FSFE fellow   #364 |
Jihui Choi
2013-08-18 15:43:57 UTC (over 11 years ago)
Help building help.
wow.. it works! I made a pdf file for korean. it doesn't show any korean character though.
I reckon that's just a font problem. I read a document about this before.
Thank you, Marco!!
ps. I'm going to Milan in the middle of Sep. if you are in Italy, I want to meet you. :)
Jihui Choi
anyway... to me...
make pdf-it
works ;-)
and even ...
make pdf-ko
Marco Ciampa
| FSFE fellow #364 |
Marco Ciampa
2013-08-19 09:04:15 UTC (over 11 years ago)
Help building help.
Same problem here.
Only chapter titles in korean chars. The other text is blank... :-(
I've made a
apt-get install texlive-full
with no visible difference though.
I think that this is a _big_ problem for many reasons:
1) english is more understandable by American and European people than for asiatic people. It is a bit hironic that asiatic people (pdf) translation isn't working...
2) now that we have a constant korean translator voluteer we have to do something to not make him go away... ;-)
Marco Ciampa
| Linux User  #78271 |
| FSFE fellow   #364 |
Jihui Choi
2013-08-19 10:01:05 UTC (over 11 years ago)
Help building help.
I did install texlive-full as well on ubuntu 12.04 Though there are still problems, I'm happy with it. At least I can make a pdf for korean and that means I can move to next step.
And when I started this work, I said I wanted to do this for many years like 10-20 years.
I stopped it for a while because of my long trip for almost 3 years and others.. But now I'm back and I believe someone will show up to work with me soon. :)
Jihui Choi
Same problem here.
I've made a
Marco Ciampa
| FSFE fellow #364 |
Kolbjørn Stuestøl
2013-09-07 12:15:07 UTC (over 11 years ago)
GIMP doc on Cygwin
The version of Cygwin which I have used for years refused a month or so ago to work with the programs used for translating GIMP documents. Perhaps because I switched to a 64 bits computer. I therefore had to install 64 bits Cygwin, but alas I have forgotten which packages needed.
I remember there was some problems but not the solutions and neither where to find the threads where the installation(s) was discussed. Julien, are your "cookbook" (Using Cygwin for GIMP translations) still available somewhere?
Someone who remembers and are willing to help me?
Kolbjoern Stuestoel
Marco Ciampa
2013-09-07 17:04:43 UTC (over 11 years ago)
GIMP doc on Cygwin
Kolbjoern Stuestoel
Why not install Virtualbox and inside it a Linux (Ubuntu) machine? In that case I can help ...
Marco Ciampa
| Linux User  #78271 |
| FSFE fellow   #364 |
Kolbjørn Stuestøl
2013-09-08 08:49:36 UTC (over 11 years ago)
GIMP doc on Cygwin
Den 07.09.2013 19:04, skreiv Marco Ciampa:
Kolbjoern Stuestoel
I am a bit lazy, Marco, and as I have used Cygwin for several years I hold on it. But perhaps Virtualbox is worth a try. I'l give it a look.
(At the moment I have to use my ten years old Windows XP computer for this work, but would like to update on a newer computer). Kolbjoern
Julien Hardelin
2013-09-10 19:30:14 UTC (over 11 years ago)
GIMP doc on Cygwin
Unfortunately no.
But did you try cygwin + git on Google ?
Julien
Kolbjørn Stuestøl
2013-09-10 21:25:27 UTC (over 11 years ago)
GIMP doc on Cygwin
Den 10.09.2013 21:30, skreiv Julien Hardelin:
Unfortunately no.
Nice to hear from you.
Yes, I have searched several times and have found some old threads, so perhaps I will manage it some rainy day. It is not very important as I still am able to use an old computer. In fact the one you and some others helped me to set up many years ago. :-)
The main reason for changing to 64 bits is the speed and of course the safety in having Cygwin/git etc. running on two or more computers.
The reason for the trouble is that Cygwin refuses to update my 32 bits version running on a 64 bits computer. I have to install the 64 bits version.
Kolbjoern
Julien
Kolbjørn Stuestøl
2013-09-10 22:13:49 UTC (over 11 years ago)
It looks like I have forgotten something, so: How do I update the quickreference/po/nn.po file?
I tried to add it the same way as the others po files, i.e. git add -> git commit -> git push, but failed.
BTW: The Norwegian file in Keys and Mouse Quickreference (PDF) on the docs.gimp.org site is missing.
Kolbjoern
2013-09-11 04:11:09 UTC (over 11 years ago)
Failed how? :)
Alexandre
Kolbjørn Stuestøl
2013-09-11 17:04:56 UTC (over 11 years ago)
Den 11.09.2013 06:11, skreiv Alexandre Prokoudine:
Failed how? :)
Sorry. I deleted all messages and do not remember them. Do your question means that i could use add -> commit -> push the normal way? I'll give it a new try during this night. Kolbjoern
Alexandre
