Using Gegl with PIL (Python Image Library)
Using Gegl with PIL (Python Image Library) hhhh xhdhx 11 Jun 13:15
  Using Gegl with PIL (Python Image Library) hhhh xhdhx 11 Jun 13:20
   Using Gegl with PIL (Python Image Library) Daniel Sabo 11 Jun 14:35
hhhh xhdhx
2013-06-11 13:15:42 UTC (almost 12 years ago)
Hi ,
We are currently using PIL , we want to use Gegl for some image effects , could you tell me how to load a string buffer into gegl and then output a string buffer instead of saving it to a file .
Thanks John
hhhh xhdhx
2013-06-11 13:20:01 UTC (almost 12 years ago)
I tried using gegl_buffer_set , but I could not get it to work in the Python binding
Thanks
On Tue, Jun 11, 2013 at 6:45 PM, hhhh xhdhx wrote:
Hi ,
Thanks John
Daniel Sabo
2013-06-11 14:35:13 UTC (almost 12 years ago)
This is missing from the introspection binding, could you try this patch and see if it meets your needs?
Thanks, - Daniel
Thanks
Hi ,
Thanks John
_______________________________________________ gegl-developer-list mailing list
gegl-developer-list@gnome.org
https://mail.gnome.org/mailman/listinfo/gegl-developer-list
