Appropriate scales for curves and levels
Appropriate scales for curves and levels Elle Stone 10 Jun 19:28
  Appropriate scales for curves and levels Michael Natterer 10 Jun 19:59
   Appropriate scales for curves and levels Elle Stone 10 Jun 22:38
Elle Stone
2013-06-10 19:28:45 UTC (almost 12 years ago)
Hi all,
When working on a 16-bit integer or 32-bit floating point image, Gimp from git "levels" tool shows increments of 0.1 on a scale from 0 to 100.0, theoretically giving 999 increments.
However, when using levels to slowly raise or lower the black point or the white point, the displayed input/output number jumps by 1 halfway between integer increments - eg jumps from 0 to 1 at 0.5, from 1 to 2 at 1.5, and so forth. And the image display doesn't change until the jump occurs. So instead of 999 increments, there are really only 99 increments, less than half as many increments as are available with any 8-bit image editor using a scale that runs from 0 to 255.
Whether 99 increments or 255 increments, both scales are too coarse for accurately setting a black point (levels or curves) or modifying tonality in the shadows (curves) of a linear gamma image. 99 increments is not all that great for more perceptually uniform color spaces, either.
At one point Gimp had a very fine-grained scale for curves, even though it only supported 8-bit image editing. Now that Gimp supports high bit depths, are there there plans to (re)introduce fine-grained curves and levels scales to match the higher bit depths?
Matching the scales for curves, levels, eye-dropper/pointer/sample points:
The levels scale is from 0.0 to 100.0 except for 8-bit images, where the scale is from 0 to 255.
The curves scale and histogram "info" scale are always from 0 to 255, regardless of the image bit depth.
The RGB eye-dropper (which recently has seen some serious love from someone - whoever you are, thank you!) displays RGB values from 0 to 255, 0 to 65535, or 0 to 1.00000, depending on the bit-depth of the image. (The floating point eye-dropper also shows values that are less than 0 and greater than 1 - again, thank you most wonderful person for making possible the proper eyedroppering of floating point hdr/exr images without having to resort to Cinepaint or Krita!)
As going back and forth between curves, levels, and the eye-dropper is such a basic and common action while editing, it would be nice if the various scales always matched each other at any given bit depth. As it is, I end up dividing and multiplying a lot to translate between the different scales.
I would request/suggest making all 8-bit scales (eye-dropper, levels, curves, and of course the pointer information and sample points) as 0-255, all 16-bit integer scales as 0-65535, and all floating point scales (eye-dropper, levels, curves, pointer, sample points) as 0 to 1.000000, so at any given bit depth all three ways of sampling/viewing/modifying the image match.
Kind regards, Elle
http://ninedegreesbelow.com - articles on open source digital photography
Michael Natterer
2013-06-10 19:59:32 UTC (almost 12 years ago)
Hi Elle,
On Mon, 2013-06-10 at 15:28 -0400, Elle Stone wrote:
Hi all,
That was simply a bug, fixed now:
commit 875b1705fc9fa61fb742c6609f46b1f753c41f29 Author: Michael Natterer
Date: Mon Jun 10 21:51:15 2013 +0200
app: don't ROUND() all input/output values to int in GimpLevelsTool
That was a leftover from before the change to 0..100 sliders for non-8-bit images. Spoted by Elle Stone.
Don't assume that all bugs are intentional features ;) The != 8-bit code generally seems to work flawlessly, but there are still rough, edges, particularly in the GUI display of values. They are all bugs though.
That's work-in-progress, I have already changed the histogram code in my tree to move towards being proper.
I proudly take the credit for that :)
That is definitely the plan...
...however I am not sure if we really want the values from the eyedropper's "Pixel" mode in all sorts of GUIs. But it will definitely not stay 0..255, that's for sure :)
Regards, --Mitch
Elle Stone
2013-06-10 22:38:05 UTC (almost 12 years ago)
Hi Mitch,
Thanks! Now the levels tool really does have 999 increments (and I really should stop assuming everything "as is" is a feature rather than a bug).
Elle
