npy saving operation
npy saving operation Dov Grobgeld 28 May 21:27
  npy saving operation Michael Henning 28 May 21:53
   npy saving operation Dov Grobgeld 29 May 07:41
    npy saving operation Øyvind Kolås 29 May 15:23
Dov Grobgeld
2013-05-28 21:27:18 UTC (almost 12 years ago)
I finished a saver operation for floating point npy images. It may e.g. be used to debug floating point operations (e.g. gaussian-blur) with numerical python. The resulting image may be read into numpy as follows:
import numpy img = numpy.load('image.npy')
It may also be viewed in my image viewer giv (though it currently does not support color npy images).
Is it ok to commit it?
Follows the code.
Regards, Dov
/* This file is an image processing operation for GEGL *
* GEGL is free software; you can redistribute it and/or * modify it under the terms of the GNU Lesser General Public * License as published by the Free Software Foundation; either * version 3 of the License, or (at your option) any later version. *
* GEGL is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU * Lesser General Public License for more details. *
* You should have received a copy of the GNU Lesser General Public * License along with GEGL; if not, see . *
* Copyright Dov Grobgeld 2013
* This operation saves a buffer in the npy file format. It may be * read into python as follows:
* import numpy
* img = numpy.load('image.npy')
#include "config.h"
#include
#ifdef GEGL_CHANT_PROPERTIES
gegl_chant_string (path, _("File"), "", _("Target path and filename, use '-' for stdout."))
#else
#define GEGL_CHANT_TYPE_SINK #define GEGL_CHANT_C_FILE "npy-save.c"
#include "gegl-chant.h" #include
static int npywrite(FILE *fp, guchar *data, int width, int height, int num_channels)
char header[100];
unsigned short header_len;
// Write header and version number to file fwrite("\223NUMPY"
"\001\000"
, 1, 8, fp);
if (num_channels == 3)
sprintf(header,
"{'descr': ');
#endif
Michael Henning
2013-05-28 21:53:18 UTC (almost 12 years ago)
Using sprintf like that opens you up to to buffer overflows. Could you switch that part of the code to use fprintf directly on the file pointer? It would also simplify the code.
Otherwise, I have nothing against committing this.
Follows the code.
Regards, Dov
* import numpy
#include "config.h"
#include
#else
char header[100];
"\001\000"
, 1, 8, fp);
sprintf(header,
"{'descr': ');
#endif
_______________________________________________ gegl-developer-list mailing list
gegl-developer-list@gnome.org
https://mail.gnome.org/mailman/listinfo/gegl-developer-list
Dov Grobgeld
2013-05-29 07:41:53 UTC (almost 12 years ago)
Ok. I'll use GString instead, as I need both the length of the resulting string as well as the string, and thus can't use fprintf (unless I fseek backwards).
Thanks,
Dov
On Wed, May 29, 2013 at 12:53 AM, Michael Henning
be
numerical
not
Follows the code.
Regards, Dov
* import numpy
#include "config.h"
#include
#else
char header[100];
"\001\000"
, 1, 8, fp);
sprintf(header,
"{'descr': ': (%d,
%d), }
\n",
height, width);
header_len = strlen(header); fwrite(&header_len, 2, 1, fp);
fwrite(header, header_len, 1, fp);
fwrite(data, width*height*num_channels, sizeof(float), fp);
return 0; }
static gboolean
process (GeglOperation *operation, GeglBuffer *input, const GeglRectangle *rect,
gint level) {
GeglChantO *o = GEGL_CHANT_PROPERTIES (operation);
FILE *fp; guchar *data;
gsize bpc;
gsize numsamples;
gsize numchannels;
gboolean ret = FALSE;
const Babl *output_format;
const Babl *input_format = gegl_buffer_get_format(input);
// Get the current format and use it to decide whether to save // the output in color or gray level formats. bpc = sizeof(gfloat);
if (babl_format_get_n_components(input_format) >= 3) {
numchannels = 3;
output_format = babl_format("RGB float"); }
else
numchannels = 1;
output_format = babl_format ("Y float"); }
numsamples = rect->width * rect->height * numchannels;
data = g_malloc (numsamples * bpc); gegl_buffer_get (input, rect, 1.0, output_format, data, GEGL_AUTO_ROWSTRIDE, GEGL_ABYSS_NONE);
fp = (!strcmp (o->path, "-") ? stdout : fopen(o->path, "wb") );
npywrite(fp, data, rect->width, rect->height, numchannels);
g_free (data);
return ret; }
static void
gegl_chant_class_init (GeglChantClass *klass) {
GeglOperationClass *operation_class; GeglOperationSinkClass *sink_class;
operation_class = GEGL_OPERATION_CLASS (klass); sink_class = GEGL_OPERATION_SINK_CLASS (klass);
sink_class->process = process; sink_class->needs_full = TRUE;
gegl_operation_class_set_keys (operation_class, "name" , "gegl:npy-save", "categories" , "output",
"description" ,
_("NPY image saver (Numerical python file saver.)"), NULL);
gegl_extension_handler_register_saver (".npy", "gegl:npy-save"); }
#endif
Øyvind Kolås
2013-05-29 15:23:00 UTC (almost 12 years ago)
numerical
not
It would be good to avoid fetching the whole buffer with gegl_buffer_get; GeglBuffer can store larger than RAM images and a malloc this large might fail. It would be better to use a loop either over scanlines of the image or groups of scanlines (32 or 64 at a time).
/Øyvind K.
                                                 -- William Gibson
http://pippin.gimp.org/                            http://ffii.org/
