Why can't we alter a filter-setting after processing...without recalling this filter?
Why can't we alter a filter-setting after processing...without recalling this filter? shepherdsbush@post.com 24 May 07:24
  Why can't we alter a filter-setting after processing...without recalling this filter? Alexandre Prokoudine 24 May 08:59
2013-05-24 07:24:38 UTC (over 12 years ago)
Dear developers,
I want to point on a general weakness of Gimp! I never understood, why filter-windows have only the buttons "OK" and "Cancel"! If you use a filter, and you are satisfied with what you see on the little preview, you click "OK" and then you see on the big picture, that it's not satisfying. So you have to recall the filter again and make a better setting....and so on! Wouldn't it be nice, to use a filter, find a setting, and if you see then after processing on the big picture, that the filter-setting could be improved, you alter this setting a little bit And then after you found the optimal setting....then you click OK.
1. Is it possible to implement this soon? Maybe a third button "stay a little while" :) 2. Why haven't this major feature implemented for so many years? 3. Is this for the developers a very complicated thing?
Thank you for this great program....and sorry for my probably bad english.
Kind Regards
Thomas
2013-05-24 08:59:45 UTC (over 12 years ago)
Some of the foundation for that has been laid in the current unstable version, but it's most likely not a 2.10 feature -- rather 3.0 or maybe 3.2.
Because the code doesn't write itself :)
Implementing non-destructive filters demands a complete switch to a different image processing core which is what we've been working on for the past several years. Yes, it's not a trivial change.
