GIMP - Installed language!
GIMP - Installed language! Mirella Istrate 19 May 10:36
  GIMP - Installed language! Michael Schumacher 19 May 10:46
   GIMP - Installed language! Guillermo Espertino (Gez) 20 May 00:52
Mirella Istrate
2013-05-19 10:36:13 UTC (almost 12 years ago)
Dear ALL
Just a "stupid" question: WHY I cannot install "GIMP" in my preferred language (English)??????? I live in this moment in Switzerland and it is impossible to install other as German language!!!
Thank you for an answer and solution. Best Regards, Mirela
2013-05-19 10:46:21 UTC (almost 12 years ago)
You can choose the language used during the install - English is available there, as well as some others, more translations are welcome - and you can change the language of the GIMP UI in the preferences.
-- Regards,
2013-05-20 00:52:36 UTC (almost 12 years ago)
El 19/05/13 07:46, Michael Schumacher escribi:
Michael: That's true for Windows (I don't know if that applies to Mac too), but language can't be chosen during install in linux and GIMP will default to the system's language.
However, as you said, it's easy to change it using the preferences.
@Mirella: Are you using GIMP 2.8.x, right?
