Invoking save dialog from within plugin
Invoking save dialog from within plugin Tibor Bamhor 14 May 09:12
  Fwd: Invoking save dialog from within plugin Tibor Bamhor 14 May 09:56
Tibor Bamhor
2013-05-14 09:12:45 UTC (almost 12 years ago)
Hi
one or two short quetions:
I am using gimp_image_duplicate() call in C plugin - obviously it works, but:
1) how can I make the new image visible? (In fact I dont need this, I am just curious here....)
2) how can I invoke "save" dialog for this new image? I am fine with new image not being visible, I just want the user enter new name/location to save that new image.
Thanks!
Tibor Bamhor
2013-05-14 09:56:27 UTC (almost 12 years ago)
Hi
an update to my question:
I managed to find gimpfileops - so I got closer to solution, I am using this call:
gimp_file_save() and have two other questions
1.) drawable ID=layer ID Correct? 2.) I can get png options dialog, but no filename and directory selection dialog!? I used "test.png" as both filenames and it saved the file into current directory (I run the gimp from console). And this is not enough
Thanks
---------- Forwarded message ---------- From: Tibor Bamhor
Date: 2013/5/14
Subject: Invoking save dialog from within plugin To: gimp-developer
Hi
Thanks!
