Selective gaussian blur port to gegl
7 of 7 messages available
Selective gaussian blur port to gegl Karthikeyan S 06 Apr 10:14
  Selective gaussian blur port to gegl Øyvind Kolås 06 Apr 19:39
   Selective gaussian blur port to gegl Victor Oliveira 06 Apr 20:50
    Selective gaussian blur port to gegl Karthikeyan S 07 Apr 15:09
     Selective gaussian blur port to gegl Michael Natterer 07 Apr 21:11
      Selective gaussian blur port to gegl Øyvind Kolås 08 Apr 09:28
       Selective gaussian blur port to gegl Karthikeyan S 13 Apr 15:53
Karthikeyan S
2013-04-06 10:14:17 UTC (about 12 years ago)
Hi all,
I am trying to port the selective gaussian blur filter to gegl. I do not understand the following lines in the original gimp code and what purpose they serve.
Line 668
if (has_alpha)
d *= src_b[nb - b]; // ?
Line 676if (has_alpha)
rowsum >>= 8; // why?
rowfact >>= 8;}
Also, as of now, my implementation correctly maintains edges in checker board images while blurring other areas. I am trying to debug another issue wherein I see that the noise pixels (in complete dark background in the checkerboard image) seem to get smeared out to neighbourhood areas and we get large patches of white arround the blurred pixel (This does not happen in gimp implementation). I am trying to see if the above lines have some clue to that.
Thanks,
Karthik
Øyvind Kolås
2013-04-06 19:39:56 UTC (about 12 years ago)
Thank you for poking around looking for more things to bring over to GEGL. I do not know much about the GIMP plug-in, but can tell you some other bits of information that could be relevant ;)
The core part of "selective gaussian blur" is what is normally called "bilateral filtering" in academic image processing circles. GEGL already has a (rather slow) bilateral filter implemented contained in operations/common/bilateral-filter.c
The specifics of the behavior of GIMPs selective-gaussian blur is something I'd consider a historic artifact - that we might not want to preserve in future versions.
(As to the lines you've pointed out, looking at them in isolation.. this seems to be code that deals with correctly handling alpha; GEGL does this normally by processing buffers with premultiplied alpha, this seems to be manual hacks that scales the contribution of pixels to the sum by the alpha.. and since legacy GIMP is 8bpc, >>= 8, is the same as /256 and 256 is 1.0, which normalizes the effect of multiplying by the alpha values between 0 and 255.)
On Sat, Apr 6, 2013 at 12:14 PM, Karthikeyan S wrote:
Hi all,
Line 668 if (has_alpha)
rowfact >>= 8;}
Thanks,
Karthik
gimp-developer-list@gnome.org
                                                 -- William Gibson
http://pippin.gimp.org/                            http://ffii.org/
Victor Oliveira
2013-04-06 20:50:01 UTC (about 12 years ago)
Just a comment, I implemented recently a much faster version of the bilateral-filter. Though I think there is still some polishing to do, it is basically working in the CPU and the GPU.
Hi all,
Line 676
if (has_alpha)
rowfact >>= 8;
Thanks,
Karthik
The future is already here. It's just not very evenly distributed -- William Gibson http://pippin.gimp.org/ http://ffii.org/
Karthikeyan S
2013-04-07 15:09:20 UTC (about 12 years ago)
in operations/common/bilateral-filter.c Doh! Thanks Øyvind.
I am stopping right away. Taking a look at your code.
I should stop relying on http://wiki.gimp.org/index.php/Hacking:Porting_filters_to_GEGL for latest info.
While I am at it, why does edge-sobel add extra pixels to the original image? Is it a 'don't care' thing.
GEGL. I
bits of
has
something
256
Hi all,
purpose
they serve.
Line 676
if (has_alpha)
rowfact >>= 8;
issue
we
happen
Thanks,
Karthik
«The future is already here. It's just not very evenly distributed» -- William Gibson http://pippin.gimp.org/ http://ffii.org/
Michael Natterer
2013-04-07 21:11:36 UTC (about 12 years ago)
Just because something is in git doesn't mean it's correct :)
If there is strange behavior, a look at the code, a bug report, or even a patch are appreciated.
--mitch
Øyvind Kolås
2013-04-08 09:28:12 UTC (about 12 years ago)
On Sun, Apr 7, 2013 at 11:11 PM, Michael Natterer wrote:
While I am at it.
Please start new threads, or change the topic - when changing the topic.
No - for the same reason that gaussian blur adds extra pixels to the original buffer; assuming an abyss behavior of zeroed pixels around the buffer. Both of these filters have well defined results. For a drop-shadow added to a layer you do intend to blur the contents out into nothingness - all such area filters with a dependendant neighbourhood are at the core - at GEGL graph level is concerned, growing their defined inputs.
--mitch
                                                 -- William Gibson
Karthikeyan S
2013-04-13 15:53:28 UTC (about 12 years ago)
Thanks for the clarifications. Will take care to change topic next time.
While I am at it.
--mitch
