GIMP and wmii
8 of 8 messages available
GIMP and wmii Andrew Shadura 18 Mar 22:30
  GIMP and wmii Liam R E Quin 19 Mar 01:38
   GIMP and wmii Andrew Shadura 19 Mar 06:41
    GIMP and wmii Andrew Shadura 29 Mar 13:17
     GIMP and wmii Alexandre Prokoudine 29 Mar 13:34
      GIMP and wmii Andrew Shadura 29 Mar 13:43
       GIMP and wmii Elle Stone 29 Mar 16:10
        GIMP and wmii Burnie West 29 Mar 16:34
Andrew Shadura
2013-03-18 22:30:27 UTC (about 12 years ago)
GIMP and wmii
I'm investigating an issue with running GIMP later than 2.6 under wmii window manager. The issue occurs when GIMP is being run in the stacked tiling mode, when inactive windows are collapsed to their titlebars only, and the active one is maximised to the rest of the column (see here, for example: http://img132.imageshack.us/img132/9492/nntex.png).
The symptoms are the following. Right after the splash screen disappears, the main window is displayed maximised. The next window to appear, the layers toolbox, becomes maximised too, while main window collapses to the title. Next, one more toolbox appears, becomes maximised as well, simultaneously collapsing others to titlebars. Right then, the toolbox which appeared last, disappears, revealing the layers toolbox, which then disappears as well. The main window stays. Then sequence is repeated: layers toolbox appears, tools appear, disappear, layers disappear. This continues few times very quickly, and then stops, and no toolboxes are shown. Whenever I try to make them appear again, this repeats. I have a short video of the process, but I couldn't manage to record it with proper frame rate, so it doesn't look exactly as it is; however, if needed I may publish it.
If I switch to the different layout, when the vertical space is divided between windows, this doesn't happen.
It seems to me that toolboxes request some fixed size which is much smaller than the screen size, and when they become maximised, this size is later rejected by toolbox management code, so it tries to re-create window once more. I tried to find a place in the code I could try to debug, and, as I'm still not familiar with the code, I don't know yet where to do that. I'd be glad if someone could direct me into the right place.
P.S. We've also tried to debug the issue from the WM side; the author said it doesn't seem like a problem in the WM but in GIMP. I also think that's the case; also, this problem didn't exist in 2.6 and previous versions, so obviously something's changed in GIMP code right after.
P.P.S. Please Cc: me when replying, I'm not subscribed to the list.
WBR, Andrew
Liam R E Quin
2013-03-19 01:38:09 UTC (about 12 years ago)
GIMP and wmii
If there's a GIMP visible in that screenshot I'm afraid it's not obvious to me.
It might be from your prose that running gimp in "single window mode" would address your problems, but I'm not certain, never having come across wmii before (is it related to wm2? doesn't look like it).
You might want to experiment with the settings for Window Mangement in Edit/Preferences (some or all of these might only be available in development builds of GIMP, I'm not sure).
I take it that this is in some sort of GNU/Linux operating environment and that you're using the GIMP 2.6 from the Linux distribution's package manager. If so, please let us know *exactly* which versions of GIMP you tried and exactly where you got them, along with the wmii version, the Linux distribution, and the version.
You might want to subscribe for a few days, or, alternatively, report this using the GIMP bug reporting system (Bugzilla), being careful to state expected and actual behaviour and versions of everything that might be relevant.
The primary testing platform for GIMP 2.6 was Debian GNU/Linux with GNOME 2. Are you running gnome-session and using wmii as your GNOME Window Manager?
Liam
Andrew Shadura
2013-03-19 06:41:43 UTC (about 12 years ago)
GIMP and wmii
No, there's no GIMP there, I did link that screenshot just to demonstrate the stacked layout: if you look at that, you may notice some of the windows are collapsed. I can't currently reproduce this layout with GIMP running for aforementioned reasons.
No, it doesn't. I don't like single window mode, it doesn't go well with my workflow. Also, last time I tried it has some issues, so it's way too early for it yet.
No, I'm talking about versions of GIMP starting from 2.7.*, including GIMP 2.8.0 and 2.8.4. Basically, it seems to me, the single window mode introduction has broken the multiple window mode. It doesn't matter which exactly versions, they behave the same way. I have tried different versions, and even on clean installation of Debian wheezy it behaves the same way. The only thing which could be of some importance is GTK+ version, it's 2.24.13 currently, but I've tried previously with other 2.24.* versions with same effect.
No, I don't run GNOME. It's just wmii.
WBR, Andrew
Andrew Shadura
2013-03-29 13:17:35 UTC (about 12 years ago)
GIMP and wmii
I wonder, how to understand the silence — is it that nobody knows where to look at, or that nobody is willing to cooperate? I don't ask to solve the issue, I just ask to direct me so I could try to fix it myself.
WBR, Andrew
2013-03-29 13:34:39 UTC (about 12 years ago)
GIMP and wmii
Typically lack of replies means that nobody knows a possible solution. Sorry about that :)
Andrew Shadura
2013-03-29 13:43:20 UTC (about 12 years ago)
GIMP and wmii
Well, as I said many times, I don't need a solution, I asked about where to look for a specific piece of code, so I don't need to study the whole source code of GIMP. I need to find the code which defines the size of toolboxes which apparently fails to react properly to oversized windows, so it withdraws the toolbox window. There are so many modules which seem to be responsible for window management, that I can't easily find what exactly every of them does.
WBR, Andrew
Elle Stone
2013-03-29 16:10:07 UTC (about 12 years ago)
GIMP and wmii
This is not a response to your request for which sections of Gimp code are involved - sorry! However, wmii is a tiling window manager, meaning it wants to put all windows side by side, no overlaps, perhaps that is a clue to the behavior?
Probably no one has responded because wmii is not so commonly used as other window managers. Would you be willing to install perhaps another, non-tiling window manager (I use Icewm myself) to see if the problem persists? That would help pinpoint whether tiling per se is involved in the problem.
Also, does the odd behavior ever stop, with a resulting stable display of the windows? Can you use/have you tried single-window mode?
Elle
-- WBR, Andrew
http://ninedegreesbelow.com - articles on open source digital photography
Burnie West
2013-03-29 16:34:08 UTC (about 12 years ago)
GIMP and wmii
Elle
I hved a similar problem with my dual-screen setup - the way I work around it is to switch to single-window mode and then switch back to multiple window mode, which I normally use.
-- WBR, Andrew
