GSOC 2013 - n-point image deformation
9 of 9 messages available
GSOC 2013 - n-point image deformation Marek Dvoroznak 11 Mar 13:40
  GSOC 2013 - n-point image deformation Alexandre Prokoudine 11 Mar 14:03
   GSOC 2013 - n-point image deformation Marek Dvoroznak 11 Mar 21:36
    GSOC 2013 - n-point image deformation Alexandre Prokoudine 11 Mar 22:17
     GSOC 2013 - n-point image deformation Michael Muré 12 Mar 12:48
      GSOC 2013 - n-point image deformation Ville Sokk 12 Mar 14:22
      GSOC 2013 - n-point image deformation Marek Dvoroznak 12 Mar 17:01
       GSOC 2013 - n-point image deformation Alexandre Prokoudine 26 Mar 04:30
        GSOC 2013 - n-point image deformation Marek Dvoroznak 26 Mar 19:16
Marek Dvoroznak
2013-03-11 13:40:24 UTC (about 12 years ago)
I would like to participate in this year's GSOC. As a school project, I implemented as-rigid-as-possible (and as-similar-as-possible) n-point image deformation. I've thought it would be useful to have a tool implementing this in GIMP. I know that at the moment similar effect can be achieved with Cage Transform tool, but with n-point image deformation it's much easier.
I planned to make a plugin implementing this type of deformation as a part of my thesis, but unfortunately I had to change my thesis' topic.
Could this be a suitable project for GSOC under GIMP?
I'm attaching a link to a video clip showing a character deformed using Cage Transform tool and also using as-rigid-as-possible deformation: http://youtu.be/ieaHvHAcNRE
Regards, Marek
2013-03-11 14:03:11 UTC (about 12 years ago)
So this is more like Puppet Warp really :) And it does look very impressive!
IMHO, it would be a great GSoC project.
How is it performance-wise? How well does it work on fairly large images?
Marek Dvoroznak
2013-03-11 21:36:43 UTC (about 12 years ago)
I have it currently written in Java and performance on fairly large images isn't so good. I suppose that in C and with more optimizations it will be much better. Performance and behavior of the algorithm very depends on a size of mesh's squares (or triangles). I'll try to do some performance tests.
Marek
2013-03-11 22:17:28 UTC (about 12 years ago)
Well, I'm not really trained to talk of such things, but one thing worth thinking of is how precise your method is trying to be.
One of the reasons why Cage Transform is so slow is that it's trying to be too smart and does too much computation.
The plan was to eventually start using poly2tri-C library that implements Delaunay triangulations. Does it ring a bell?
I'm sure, Michael Mur can provide much more useful info :)
Alexandre
Marek
Michael Muré
2013-03-12 12:48:17 UTC (about 12 years ago)
The reason the cage tool is slow is that a set of coefficient is computed and used to deform every single pixel inside the cage. The plan was indeed to use the poly2tri-C to mesh the cage and move that instead of each pixels.
There is not that much work to do that, as most of the code can be reused, and this library is already used in the seamless clone tool.
Another thing to look at is the new Free Transform Tool of Krita, wich looks quite awesome: http://krita.org/item/131-free-transform-tool
It's based on this paper: http://faculty.cs.tamu.edu/schaefer/research/mls.pdf
2013/3/11 Alexandre Prokoudine
Alexandre
Marek
Ville Sokk
2013-03-12 14:22:02 UTC (about 12 years ago)
Put the titles in ACM digital library and click on "Cited by" and you may find interesting articles that are newer.
Marek Dvoroznak
2013-03-12 17:01:38 UTC (about 12 years ago)
That would speed it up a lot I think.
Thank you for the information. I didn't know that Krita has it implemented.
My proposed implementation is also based on this paper but with some differences. I should make a proposal with more details – but it'll take some time.
Marek
2013-03-26 04:30:44 UTC (about 12 years ago)
My proposed implementation is also based on this paper but with some differences. I should make a proposal with more details but it'll take some time.
In the mean time please try to find some time and compile GIMP from source code in Git master branch. We'd like our students to have a working build environment prior to starting actual development :)
Most development discussions happen on IRC (#gimp on GIMPnet). We don't demand participation there (after all, not everybody likes IRC), it's just the easiest way to stay connected.
Marek Dvoroznak
2013-03-26 19:16:29 UTC (about 12 years ago)
I've already compiled GIMP from sources on Git, and played a little with GEGL and goat exercise.
I'm idling in #gimp as korek :)
Marek
Alexandre Prokoudine píše v Út 26. 03. 2013 v 08:30 +0400:
gimp-developer-list@gnome.org
