ImageMap plugin crashed
ImageMap plugin crashed Sashi Kumar 19 Feb 14:42
  ImageMap plugin crashed Mukund Sivaraman 20 Feb 13:22
Sashi Kumar
2013-02-19 14:42:30 UTC (about 12 years ago)
I open an image in Gimp 2.8.5 and open the Imagemap plugin. I edited the default URL in Map Info (Mapping -> Edit Map Info...) inside quotes ( example: "www.gimp.org" ) and saved the imagemap. While loading the same map file I get the following message:
*Plug-in crashed: "imagemap" *
*(/usr/lib/gimp/2.0/plug-ins/imagemap)
* *The dying plug-in may have messed ip GIMP's internal state. *
*You may want to save your images and restart GIMP to be on the safe side.*
Is that a Bug? Or is it by default? If so it should show an error message and should not be save.
K Sashi Kumar
Mukund Sivaraman
2013-02-20 13:22:39 UTC (about 12 years ago)
Hi Sashi
Because you want to participate in the GSoC program, how about you tell us why it crashed? :) See if you can first make a backtrace for this crashing plug-in. There are some instructions in the devel-docs/ directory on how to attach a debugger to a plug-in process. See devel-docs/debug-plug-ins.txt.
Then locate what part of the code this plug-in crashed with, and what data it was processing when it crashed. Find the bug in the code.
Mukund
