GEGL Crashes GPU
| GEGL Crashes GPU | Partha Bagchi | 15 Feb 03:52 |
| GEGL Crashes GPU | Tobias Ellinghaus | 15 Feb 10:47 |
| GEGL Crashes GPU | Victor Oliveira | 16 Feb 00:22 |
| GEGL Crashes GPU | Partha Bagchi | 16 Feb 02:29 |
| Trouble compiling plugin in windows | Sebastian Kraft | 17 Feb 17:19 |
| Trouble compiling plugin in windows | Jernej Simončič | 17 Feb 17:43 |
| Trouble compiling plugin in windows | Sebastian Kraft | 17 Feb 19:05 |
| GEGL Crashes GPU | Victor Oliveira | 19 Feb 18:53 |
| GEGL Crashes GPU | Partha Bagchi | 21 Feb 01:44 |
GEGL Crashes GPU
Hi Victor,
Latest git. I have an NVIDIA GeForce GT 230M card with 1G VRAM. The opengl version is 1.1 CUDA 4.2.1 etc. Windows 7 64bit
I think OpenCL is taking down my video every time. Here is a simple repeatable test for me.
1. Open 16 bit tiff.
2. Duplicate layer.
3. Layer - desaturate -> invert
4. GEGL gaussian blur x = y = 150.
Takes the screen down (goes black and recovers) and leaves a dark tile on the layer.
Any ideas?
Also, As I was mentioning to you before:
$ ls -al /c/Program\ Files/NVIDIA\ Corporation/OpenCL/
total 116
drwxr-xr-x 2 partha Administrators 0 Feb 3 22:55 .
drwxr-xr-x 11 partha Administrators 4096 Feb 3 22:55 ..
-rwxr-xr-x 1 partha Administrators 53024 Jan 28 17:39 OpenCL.dll
-rwxr-xr-x 1 partha Administrators 61216 Jan 28 17:39 OpenCL64.dll
OpenCL64.dll seems bigger. So, should that be the default DLL for windows 7 64bit?
Thanks,
Partha
GEGL Crashes GPU
Am Freitag, 15. Februar 2013, 04:52:49 schrub Partha Bagchi:
Hi Victor,
1. Open 16 bit tiff. 2. Duplicate layer.
4. GEGL gaussian blur x = y = 150.Takes the screen down (goes black and recovers) and leaves a dark tile on the layer.
Any ideas?
That is normal when running OpenCL (or CUDA) kernels on a GPU that has a monitor connected. On Windows it will time out quite quickly, on Linux AFAIK not. However, that can be configured. Google is your friend, just search for "nvidia watchdog".
Thanks,
Partha
Tobias
GEGL Crashes GPU
Hi Partha,
Thanks for the bug report, I'll give a look when I can. Notice that a 150x150 radius is very big and maybe yout GPU doesn't have enough memory for that, but it was supposed to fallback to the CPU in this case.
Thanks
Victor
Hi Victor,
opengl
Any ideas?
"nvidia watchdog".[...]
Thanks,
ParthaTobias
gimp-developer-list@gnome.org
GEGL Crashes GPU
Hi Victor,
I have an NVIDIA GPU with 1G dedicated VRAM, i7 Core CPU, and 16G of RAM. In any case, 150x150 radius should be doable. In any case, I am sure that when Gimp goes production, it's bound to come up.
Any further report on Mac? While I am finding that it's quite fast on an Mac with 8G RAM, I am not sure if the GPU is being used.
Note that everything I have seen/ read about OpenCL says that you don't need to load the library at least on a Mac.
Thanks, Partha
On Fri, Feb 15, 2013 at 7:22 PM, Victor Oliveira wrote:
Hi Partha,
Thanks
Hi Victor,
opengl
on
the layer.
Any ideas?
Thanks,
ParthaTobias
https://mail.gnome.org/mailman/listinfo/gimp-developer-list_______________________________________________ gimp-developer-list mailing list
I have some trouble compiling a plugin on a windows system with MinGW. Compilation works fine, but when GIMP tries to load the plugin during startup I get a "procedure entry point __gxx_personality_v0" not found error.
I looked at the libstdc++-6.dll that comes with GIMP and it has "__gxx_personality_sj0". So I have tried MinGW 4.5, 4.6 and 4.7 but the libstdc++-6.dll in the C:\MinGW\bin folder always has "__gxx_personality_v0".
What is the correct version of MinGW that is compatible to the windows builds of GIMP?
Best regards,
Sebastian
I'm using mingw-w64 compiled with Gentoo's crossdev package. The support libraries are from the OpenSuSE build service (I only compile GIMP myself - everything else is from OpenSuSE). Current versions use gcc 4.7.2.
I suggest you try the tdm sjlj gcc packages from here: if you're on Windows.
< Jernej Simončič ><><><><>< http://eternallybored.org/ > The meek shall inherit the earth, but NOT its mineral rights. -- Getty's Reminder
Am 17.02.2013 18:43, schrieb Jernej Simončič:
Thanks, the TDM-GCC bundle worked!
Sebastian
GEGL Crashes GPU
Hi Partha,
I couldn't really reproduce your error, so I assume it is because you're trying to use the display GPU for processing and to avoid blocking the screen, the nvidia driver just kills whatever is running in the GPU. Also, I'm not sure if you're already using the GEGL_SWAP=RAM option to run GIMP, it should improve performance and maybe you don't get this error.
On Sat, Feb 16, 2013 at 12:29 AM, Partha Bagchi wrote:
Hi Victor,
Thanks, Partha
Hi Partha,
Thanks
Hi Victor,
opengl
on
the layer.
Any ideas?
Thanks,
ParthaTobias
GEGL Crashes GPU
Hi Victor,
Sorry for the delay in responding. Like I told you the other night on gtalk, I am unable to get a log on Windows even using g_print as you suggested instead of g_message. On the Mac, I simply get that opencl is not being used since there is no shared object to load.
I think a lot of users will be using a single display (like I do using my laptop) and so, there would have to be some viable solution to problem of the nvidia driver killing the GPU job, don't you think?
I didn't know about the GEGL_SWAP= RAM option and will add that to the environment while running Gimp.
Thanks! Partha
On Tue, Feb 19, 2013 at 1:53 PM, Victor Oliveira wrote:
Hi Partha,
Hi Victor,
Thanks, Partha
wrote:
Hi Partha,
Thanks
Hi Victor,
opengl
tile on
the layer.
Any ideas?
Thanks,
ParthaTobias
