What about RAW files?
What about RAW files? Patrick 12 Feb 05:33
  What about RAW files? Ville Sokk 12 Feb 10:06
   What about RAW files? Partha Bagchi 12 Feb 10:38
    What about RAW files? Nils Philippsen 18 Feb 18:11
     What about RAW files? Partha Bagchi 19 Feb 10:52
  What about RAW files? Kevin Cozens 12 Feb 20:07
Patrick
2013-02-12 05:33:01 UTC (about 12 years ago)
I was very impressed with damn near every aspect of this product/application until I decided to see how it worked as a possible supplement/replacement for Photoshop. Everything worked fine until I attempted to load a RAW tiff out of my camera. 12MB shrank to a very distorted approx. 600k... with no options that I could find. I realize there could be an enormous impact of proprietary RAW conversion issues and maybe that's why your application does not/can not 'see' my RAW files. I find it incredibly amusing that GIMP would go 99% of Adobe Photoshop and then stop with no RAW file support. If there is no RAW support, add-on or otherwise, GIMP seems a bit overkill as a 'general' graphics/photo editor. Please tell me I overlooked it. Very, very well done though... what a labor. With RAW file processing, I could support such an endeavor. wow.
pjmason, Ph.D. Juneau, AK
Ville Sokk
2013-02-12 10:06:17 UTC (about 12 years ago)
There's RAW support in the UFRaw plugin. You can also use a separate program for RAW conversion (stand-alone UFRaw, rawstudio, darktable, photivo, raw therapee). In the future GIMP should hopefully have good RAW support out of the box.
Partha Bagchi
2013-02-12 10:38:02 UTC (about 12 years ago)
As said above, UFRaw supports all camera RAW (as supported by dcraw). However, it has not been updated in a while. In particular, it will not send 16-bit TIFF to Gimp 2.9.x. But if you want to experiment, I have built UFRaw into Gimp for Windows 64-bit and McGimp Snow Leopard and higher.
You can get my builds from my website.
product/application
tiff
no
of
GIMP
If
as a
gimp-developer-list@gnome.org
Kevin Cozens
2013-02-12 20:07:52 UTC (about 12 years ago)
Support for RAW files is available using either the dcraw or ufraw plug-in for GIMP.
Nils Philippsen
2013-02-18 18:11:27 UTC (about 12 years ago)
I've worked on a patch for ufraw which implements that. I'm not yet 100% content with it, but I'll post it upstream for a review.
Nils
Nils Philippsen / Wilhelmstraße 22 / D-71229 Leonberg
nils@tiptoe.de / nils@redhat.com
PGP fingerprint:  C4A8 9474 5C4C ADE3 2B8F  656D 47D8 9B65 6951 3011
Ever noticed that common sense isn't really all that common?
Partha Bagchi
2013-02-19 10:52:37 UTC (about 12 years ago)
That's cool! :)
Can you send me a link?
Thanks in advance, Partha
Nils --
Nils Philippsen / Wilhelmstraße 22 / D-71229 Leonberg nils@tiptoe.de / nils@redhat.com
PGP fingerprint: C4A8 9474 5C4C ADE3 2B8F 656D 47D8 9B65 6951 3011 Ever noticed that common sense isn't really all that common?
