Motion blur strange behavior
2 of 3 messages available
20121227073823.45c6e4ee@scr... 27 Dec 22:59
  Motion blur strange behavior Victor Oliveira 27 Dec 22:58
   Motion blur strange behavior Alexandre Prokoudine 28 Dec 08:36
Victor Oliveira
2012-12-27 22:58:29 UTC (almost 13 years ago)
On Thu, Dec 27, 2012 at 1:38 AM, Pavel Roschin wrote:
Hello, I noticed two strange things in using gegl's motion blur:
1. Opencl and normal versions are different - try to use ImageMagick's compare
This is because the OpenCL path doesn't support the new abyss policies, so it just uses a (0,0,0,0) pixel outside the geglbuffer boundaries, while the "normal" version is probably using clamp.
2. I have to insert node "crop" because filter produces too big buffer (bigger than initial image)
I attached test images and source code.
I see too much bugs in filters, that must work with neighborhood pixels, it seems that this is due to complicated tile nature of gegl...
Yeah... it seems some of the filters are broken, I have to dig up what is the problem, probably some of the recent changes in GEGL.
And so, some tests:
1. OpenCL version of motion-blur: 1.0 s (GeForce GT 430, year 2012) 2. CPU version of motion-blur: >10 s (Pentium 4 3.0GHz, year 2003) 3. GIMP's old version motion blur: ~2 s (faster, much faster gegl's)
10x times faster. But my CPU significantly slower and older than GPU.
In this case I hope GIMP will keep his fast (even if 8bit-per-color) filters, sometimes speed is the main thing in image processing. Or may be GEGL will have faster operations for 8-bit data?
But that's the point of using the GPU! We can have good and awesome floating-point precision and speed :)
Pavel
2012-12-28 08:36:47 UTC (almost 13 years ago)
On Fri, Dec 28, 2012 at 2:58 AM, Victor Oliveira wrote:
And so, some tests:
Since your reply landed to my inbox before the original mail, how was CPU version measured?
