rotating path?
rotating path? Kolbjørn Stuestøl 12 Dec 19:59
  rotating path? scl 12 Dec 21:25
   rotating path? Kolbjørn Stuestøl 13 Dec 10:59
Kolbjørn Stuestøl
2012-12-12 19:59:59 UTC (over 12 years ago)
rotating path?
In gimp-tool-transform.html (src/toolbox/transform/common-features.xml) there is a note:
"When rotating a path, Preview options are not valid: only Outline is active."
What does this mean? I am not able to rotate any path set with the path tool. Perhaps I have missed, forgot or misunderstood something? Kolbjoern
scl
2012-12-12 21:25:02 UTC (over 12 years ago)
rotating path?
I'm not completely sure, but it sounds like an outdated information, that the Rotate tool wouldn't show the rotating path itself, but the rectangle outline of the image.
You are able to rotate a path and to have a visual feedback for finer adjustment with the following steps:
1. Create the desired path. 2. In the Paths tab click the first field before the path to make it visible -> the eyeball like in the Layers tab will appear before the path and the path is shown on the canvas. 3. Choose the Rotate tool.
4. In the Rotate tool options dialog: behind the text 'Transform' are some toggle buttons - select the Path toggle button (the last in that row). To make the rotating path more recognizable you could select 'No guides' from the Guides list box.
5. Start rotating and confirm.
Kind regards,
Kolbjørn Stuestøl
2012-12-13 10:59:59 UTC (over 12 years ago)
rotating path?
Den 12.12.2012 22:25, skreiv scl:
I think you are right. If nobody protests I will omit this note.
Kind regards,
Thank you.
I will give it a try and perhaps rewrite the documentation if necessary. Kolbjrn
