Changing all icons of GIMP
Changing all icons of GIMP bart@neeneenee.de 12 Dec 19:05
  Changing all icons of GIMP scl 12 Dec 20:32
   Changing all icons of GIMP bart@neeneenee.de 13 Dec 12:55
   Changing all icons of GIMP bart@neeneenee.de 28 Dec 16:05
bart@neeneenee.de
2012-12-12 19:05:10 UTC (about 12 years ago)
Dear GIMP developers,
inspired by the UI of Blender i'd like to create one GTK theme for various open source
graphic software like GIMP.
My first step is the theme (which is nearly ready): http://dev.speed-dreams.org/Eckhard/blender-gimp.jpg http://ompldr.org/vMnphOA/blender-crisp.png
My 2nd step is to change all icons of GIMP. Please can you tell me how to change any icon that appears in GIMP and not only the toolbox.
Best regards Eckhard.
scl
2012-12-12 20:32:40 UTC (about 12 years ago)
Nice to see somebody is working on a smart and a bit darker UI theme for GIMP. Perhaps it's a start for a fresher look.
The icons are in the GIMP Git repository [1]. Instead of replacing the existing UI themes I recommend to propose your theme as a new one as tastes are different and there's more to a theme than a stylish look. It's also worth knowing that the GNOME Design team worked at an icon set for graphics applications [2]. To join your forces you should contact the GNOME visual design lead Jakub Steiner (jimmac) [3] or our user interaction architect Peter Sikking. You find at least jimmac at IRC in #gimp or #gnome-design.
Kind regards and keep up your good work,
[1] http://git.gnome.org/browse/gimp/tree/themes/Default/images [2] http://worldofgnome.org/creating-gnome-symbolic-icons-with-jimmac/ [3] https://live.gnome.org/Design
bart@neeneenee.de
2012-12-13 12:55:51 UTC (about 12 years ago)
Hello Sven,
thanks for your feedback. Not sure if the GIMP UI team has the same goals like i have.
My main idea is to create step by step a configuration package for various open source
graphic software for a uniform suite like the creative suite of Adobe.
This means: - themes, icons and colors
- workflows, presets and shortcuts
- sharing objects between these apps
I know this is a very big picture at all.
So here comes my question again:
Is it possible changing all icons (not toolbar only) of GIMP by a theme?
Cheers Eckhard.
gimp-developer-list@gnome.org
bart@neeneenee.de
2012-12-28 16:05:47 UTC (about 12 years ago)
Hi all,
based on the document /devel-docs/libgimpwidgets/html/libgimpwidgets-GimpStock.html of the GIMP sources i could go on creating my Blender Dark theme for GIMP and changing
some interface icons too:
http://dev.speed-dreams.org/Eckhard/blender-gimp-02.jpg
Cheers Eckhard.
