what to do with the orphaned images?
what to do with the orphaned images? Marco Ciampa 02 Dec 15:15
  what to do with the orphaned images? Roman Joost 04 Dec 05:06
Marco Ciampa
2012-12-02 15:15:27 UTC (over 12 years ago)
See the command:
$make check-images-en [SRC] src/preface/authors.xml
*** Checking image references ...
parsing XML files ...
found 1578 references in 634 files
searching images in 'images/C' ... found 1599 image files
0 broken image references 21 orphaned image files:
ORPHANED: images/C/dialogs/SaveAsCSS.png ORPHANED: images/C/dialogs/stock-reset-16.png ORPHANED: images/C/math/dot-for-dot.png ORPHANED: images/C/menus/windows/dockable-dialogs.png ORPHANED: images/C/toolbox/FG-select-smoothing1.png ORPHANED: images/C/toolbox/FG-select-smoothing2.png ORPHANED: images/C/toolbox/FG-select-smoothing3.png ORPHANED: images/C/toolbox/brush-dynamics.png ORPHANED: images/C/toolbox/dynamic-fade-example-curve-color-fade.png ORPHANED: images/C/toolbox/dynamic-fade-example-curve.png ORPHANED: images/C/toolbox/dynamic-fade-example.png ORPHANED: images/C/toolbox/dynamics-options.png ORPHANED: images/C/toolbox/perspective-clone-options.png ORPHANED: images/C/toolbox/tool-options-paint-gradient.png ORPHANED: images/C/using/dialog-highlight-dockbar.png ORPHANED: images/C/using/dialog-highlight-handle.png ORPHANED: images/C/using/dock-attached.png ORPHANED: images/C/using/dock-tab.png ORPHANED: images/C/using/imagewindow-description.png ORPHANED: images/C/using/left-vertical-line.png ORPHANED: images/C/using/standard-setup.png
Marco Ciampa
| Linux User  #78271 |
| FSFE fellow   #364 |
Roman Joost
2012-12-04 05:06:31 UTC (over 12 years ago)
Hi Marco,
IMHO they should be deleted.
Cheers,
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
