check-images error
check-images error Kolbjørn Stuestøl 23 Nov 18:16
  check-images error Kolbjørn Stuestøl 23 Nov 18:22
   check-images error Ulf-D. Ehlert 26 Nov 19:47
    check-images error Kolbjørn Stuestøl 27 Nov 16:56
     check-images error Kolbjørn Stuestøl 27 Nov 17:08
     check-images error Ulf-D. Ehlert 27 Nov 17:50
Kolbjørn Stuestøl
2012-11-23 18:16:01 UTC (over 12 years ago)
check-images error
When running "make check-images" I get this message:
/bin/sh: line 8: 6116 Aborted python tools/validate_references.py --verbose --broken --orphaned
Makefile:1611: recipe for target `check-image-references' failed make: *** [check-image-references] Error 134
Some missing packages in my computer setup or an error in the check-images-xx-program?
(I get the error message twice when running make check-images-xx.)
As far as I can see, the program does its work and lists all orphaned files. So perhaps this is a minor problem?
Kolbjoern
Kolbjørn Stuestøl
2012-11-23 18:22:21 UTC (over 12 years ago)
check-images error
OOOPS
Sent by an accident when reading the thread about the same theme. But of course, if someone has an answer Kolbjoern
Den 23.11.2012 19:16, skreiv Kolbjrn Stuestl:
Kolbjoern _______________________________________________ gimp-docs-list mailing list
gimp-docs-list@gnome.org
Ulf-D. Ehlert
2012-11-26 19:47:16 UTC (over 12 years ago)
check-images error
On Fri, Nov 23, 2012 at 07:22:21PM +0100, Kolbj�rn Stuest�l wrote: [...]
But of course, if someone has an answer … Kolbjoern
No answer, but...
I have modified the script a little bit (and also slightly changed the syntax) - who knows, maybe it's working now.
Ulf
Pleonasmus: Aberglaube.
		-- Karlheinz Deschner
Kolbjørn Stuestøl
2012-11-27 16:56:31 UTC (over 12 years ago)
check-images error
Den 26.11.2012 20:47, skreiv Ulf-D. Ehlert:
No answer, but...
Ulf
Curious as always I ran 'git pull' and then 'make check-images'. Result:
… ORPHANED: images/C/using/left-vertical-line.png ORPHANED: images/C/using/standard-setup.png /bin/sh: line 8: 6096 Aborted python tools/validate_references.py --verbose --broken --orphaned Makefile:1611: recipe for target `check-image-references' failed make: *** [check-image-references] Error 134
The error is obviously in Cygwin. There is a file /bin/sh.exe in Cygwin but I do not know what this file is doing. As I do not have the source code for this file I am unable to find out what line 8 does.
Perhaps calling a missing program or package. Who knows.
As said before, it looks like the program is doing what it is intended to do. Perhaps it is a cosmetic problem only. Or should the program do something more?
Kolbjoern
Kolbjørn Stuestøl
2012-11-27 17:08:15 UTC (over 12 years ago)
check-images error
Den 27.11.2012 17:56, skreiv Kolbjørn Stuestøl:
No answer, but...
Ulf
Kolbjoern
Forgot:
My version of sh.exe is:
GNU bash, version 4.1.10(4)-release (i686-pc-cygwin) Copyright (C) 2009 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later
Kolbjoern
Ulf-D. Ehlert
2012-11-27 17:50:03 UTC (over 12 years ago)
check-images error
On Tue, Nov 27, 2012 at 05:56:31PM +0100, Kolbjrn Stuestl wrote: [...]
The error is obviously in Cygwin. There is a file /bin/sh.exe in Cygwin but I do not know what this file is doing. As I do not have the source code for this file I am unable to find out what line 8 does. Perhaps calling a missing program or package. Who knows.
Yes, it look's like a Cygwin bug. But since I don't use and don't know Cygwin, I have no chance to find out what to do. :-(
You can try to remove as much as possible from the script (or the other way round: rebuild it from scratch) to find a minimal script which still failes with that error message, and then file a bug report for Cygwin.
No, output here is
$ make check-images *** Checking image references ...
parsing XML files ...
found 1580 references in 634 files
searching images in 'images/C' ... found 1601 image files
0 broken image references 21 orphaned image files:
ORPHANED: images/C/dialogs/SaveAsCSS.png ...
ORPHANED: images/C/using/standard-setup.png or
$ make check-images-de
... (same as above)
searching images in 'images/de' ... found 448 image files
19 orphaned image files: ORPHANED: images/de/dialogs/dialogs-new-image.png ...
ORPHANED: images/de/using/save-tiff-dialog.png
Ulf
Die Heiligenlegenden entlarvte Luther als Mrchen. An den Bibellegenden
hielt er fest; am Teufelsglauben auch; am Hexenwahn auch; an der
Ketzervertilgung auch; am Antisemitismus auch; am Kriegsdienst, an der
Leibeigenschaft, den Frsten. Man nennt es: Reformation.
