hey i have some ideas for you
hey i have some ideas for you Alex Bombay 21 Oct 00:21
  hey i have some ideas for you Clayton Walker 21 Oct 01:55
Alex Bombay
2012-10-21 00:21:32 UTC (over 12 years ago)
i know a bit about code and the mac osx system and i got to say good work guys i really like the native support but i have a few things for the project that could make it better. you could add a "drag to applications" background for the dmg and a custom drive icon or use the icon you have already for the mounted dmg file. also you could add a minimize all button or if you click any of the yellow buttons it will minimize the whole program. last but not least shorten the tool options name at the top to not have it cut off or to change the default size when it opens. thanks so much you guy for your hard work and dedication to this great project its the best you can get with out breaking the bank.
Clayton Walker
2012-10-21 01:55:13 UTC (over 12 years ago)
Yeah, haven't had much motivation to add features to the dmg, getting gimp ready for deployment in the first place is challenging enough. Also, we're still working on proper window management concepts, which could take a while.
Finally, what do you mean by this:
it cut off or to change the default size when it opens. I don't exactly understand.
Thanks for using GIMP!
On Sat, Oct 20, 2012 at 6:21 PM, Alex Bombay wrote:
i know a bit about code and the mac osx system and i got to say good work guys i really like the native support but i have a few things for the project that could make it better. you could add a "drag to applications" background for the dmg and a custom drive icon or use the icon you have already for the mounted dmg file. also you could add a minimize all button or if you click any of the yellow buttons it will minimize the whole program. last but not least shorten the tool options name at the top to not have it cut off or to change the default size when it opens. thanks so much you guy for your hard work and dedication to this great project its the best you can get with out breaking the bank. _______________________________________________ gimp-developer-list mailing list
gimp-developer-list@gnome.org
