using the capabillities of gimp through Java
using the capabillities of gimp through Java Ziyad Mohammad 03 Oct 08:45
  using the capabillities of gimp through Java Jon Nordby 03 Oct 10:37
   using the capabillities of gimp through Java Ofnuts 03 Oct 20:03
Ziyad Mohammad
2012-10-03 08:45:23 UTC (over 12 years ago)
Hi
can i connect java to gimp so that i can do some image processing on a map using java ide the ide that i will use will be either eclipse or netbeans
Jon Nordby
2012-10-03 10:37:31 UTC (over 12 years ago)
On 3 October 2012 10:45, Ziyad Mohammad wrote:
Hi
have you tried http://jgimp.sourceforge.net/? You should also be able to GEGL with gobject introspection bindings using JGIR: https://live.gnome.org/JGIR
2012-10-03 20:03:26 UTC (over 12 years ago)
Hi
Last update to JGimp was in 2003... that was before Gimp 2.0. Will it work with 2.8.2?
