Bug with sliders
Bug with sliders Loïc Guyader 21 Sep 21:52
Loïc Guyader
2012-09-21 21:52:12 UTC (over 12 years ago)
Bug with sliders
I found a bug with the sliders in scripts. Is this a known bug? I wrote a little script-fu to make it easier to understand and to show how the bug is annoying. (see an attachment)
*If you change a value with the sliders (step_inc), the value displayed is not the one that will be used in the script. e.g. 10 + 10 will be 10.31390135 + 9.865470852 = 20.1793722 e.g. 10 * 22 will be 9.865470852 x 21.52466368 = 212.3509421 This even if you choose no digit after the point. Fortunately, there is no problem with the arrows or with page key (page_inc) or by entering the value directly. I hope yous will fix the bug because scripts-fu do not work properly.*
- My OS = Windows XP SP3 (x86 Family) - *Parameter type in question = SF-ADJUSTMENT* with:
Widget argument = step_inc Increment/decrement value (= 1 in my script) Widget argument = SF-SLIDER or 0
*I opened a topic on http://registry.gimp.org/node/27472*
Best regards
Loïc
