2GB limit on Resource Consumption: Tile cache size
7 of 7 messages available
2GB limit on Resource Consumption: Tile cache size Elle Stone 17 Sep 18:23
  2GB limit on Resource Consumption: Tile cache size Liam R E Quin 18 Sep 01:32
   2GB limit on Resource Consumption: Tile cache size Elle Stone 18 Sep 12:15
    2GB limit on Resource Consumption: Tile cache size Tobias Jakobs 18 Sep 13:35
     2GB limit on Resource Consumption: Tile cache size Michael Natterer 18 Sep 18:08
      2GB limit on Resource Consumption: Tile cache size Elle Stone 19 Sep 19:11
  2GB limit on Resource Consumption: Tile cache size Jon Nordby 18 Sep 14:08
Elle Stone
2012-09-17 18:23:03 UTC (about 13 years ago)
While making changes to "Edit/Preferences/Environment, Resource Consumption: Tile cache size", I noticed a warning when I tried to increase the cache size to 2 gigabytes, or 2048 megabytes (terminal output, Gimp 2.9, started from the command line):
(gimp-2.9:3518): GLib-GObject-WARNING **: value "-2147483648" of type `gint' is invalid or out of range for property `cache-size' of type `gint'
If I set the cache size to 2047 megabytes, there is no warning. If I set the cache size to more than 2048 megabytes, the 'GLib-GObject-WARNING **: value' gets correspondingly larger.
I only have 4 GB of ram on my computer, but I have successfully given more than 2GB to other image editing programs. A lot of people have computers with way more than 4GB of ram. Would it make any practical difference to be able to use more than 2GB of ram for the tile cache when using Gimp? It seems odd to be limited to less than 2GB for the tile cache size, solely because the type is gint.
Kindest regards, Elle Stone
Liam R E Quin
2012-09-18 01:32:10 UTC (about 13 years ago)
I take it that this is a 32-bit computer and 32-bit build of GIMP?
If so, yes, 2G is likely the limit. On many 32-bit Linux systems there's also a 3G process size limit.
On 64-bit systems you can set the tile cache size larger, at least on Linux systems.
Liam
Elle Stone
2012-09-18 12:15:15 UTC (about 13 years ago)
No, it is a 64-bit computer and a 64-bit build of Gimp 2.9, running Linux (OpenSuse 12.2). It's just not a very new computer and doesn't have a lot of RAM by today's standards.
I compiled Gimp using "--enable-debug" so perhaps the terminal output that I'm seeing is only available if "--enable-debug" is used.
I can easily set the tile cache size larger than 2GB using "Edit/Preferences/Environment, Resource Consumption: Tile cache size". The problem is that when starting Gimp from the command line and then setting the tile cache size to more than 2GB, I see a warning in the terminal output telling me that the maximum tile cache size has been exceeded.
The warning says that the "type" for the tile cache size is "gint", which means 2GB really is the limit. At least on my system. To check the maximum that "gint" can hold on my system, I added in a printf statement in the lcms plug-in code that I'm working on, to print out G_MAXINT, which turns out to be 2GB. See http://developer.gnome.org/glib/stable/glib-Basic-Types.html#G-MAXINT:CAPS.
As anything greater than 2GB exceeds the limit of what "gint" can hold, I don't see how setting anything greater than 2GB through "Preferences" actually gets you more than 2GB.
Elle
Liam
Liam Quin - XML Activity Lead, W3C, http://www.w3.org/People/Quin/ Pictures from old books: http://fromoldbooks.org/ Ankh: irc.sorcery.net irc.gnome.org freenode/#xml
Tobias Jakobs
2012-09-18 13:35:40 UTC (about 13 years ago)
For me, as a not C developer, it looks like this should be changet to guint or even better guint64. But lets wait what Mitch things about this.
Regards
Tobias
Jon Nordby
2012-09-18 14:08:23 UTC (about 13 years ago)
It is probably this issue:
https://bugzilla.gnome.org/show_bug.cgi?id=648265
Michael Natterer
2012-09-18 18:08:32 UTC (about 13 years ago)
I think pull, the code was broken:
commit 52af6e3f3f67d37aa72d06a5f60b1a3967d6c297 Author: Michael Natterer
Date: Tue Sep 18 20:07:13 2012 +0200
app: fix the code that sets the 64bit tile cache size on GeglConfig
app/gegl/gimp-gegl.c | 18 ++++++++++++++---- 1 file changed, 14 insertions(+), 4 deletions(-)
--mitch
Elle Stone
2012-09-19 19:11:30 UTC (about 13 years ago)
--mitch
I did git pull and recompiled Gimp. The terminal output no longer complains when setting Preferences/Environment/Resource Consumption/Tile cache size greater than 2GB. Thank you, Mitch!
Elle
