[PATCH] gegl-init: Read debug flags before initializing opencl
[PATCH] gegl-init: Read debug flags before initializing opencl Tom Stellard 10 Sep 16:37
Tom Stellard
2012-09-10 16:37:43 UTC (about 13 years ago)
Setting the use-opencl property on the gegl_config object ends up calling gegl_cl_init(), which initializes the gegl opencl state. Since the opencl initialization was happening before the initialization of gegl_debug_flags, none of the opencl debug statements were being printed. ---
gegl/gegl-init.c | 29 +++++++++++++++-------------- 1 file changed, 15 insertions(+), 14 deletions(-)
diff --git a/gegl/gegl-init.c b/gegl/gegl-init.c index f75bad8..aa1f63c 100644
--- a/gegl/gegl-init.c
+++ b/gegl/gegl-init.c
@@ -471,6 +471,21 @@ gegl_post_parse_hook (GOptionContext *context, babl_init ();
gegl_instrument ("gegl", "gegl_init", 0);
+#ifdef GEGL_ENABLE_DEBUG
+ const char *env_string;
+ env_string = g_getenv ("GEGL_DEBUG"); + if (env_string != NULL)
+ gegl_debug_flags =
+ g_parse_debug_string (env_string, + gegl_debug_keys, + G_N_ELEMENTS (gegl_debug_keys)); + env_string = NULL;
+#endif /* GEGL_ENABLE_DEBUG */
config = (void*)gegl_config ();
if (cmd_gegl_swap)
@@ -499,20 +514,6 @@ gegl_post_parse_hook (GOptionContext *context, if (cmd_gegl_queue_limit)
g_object_set (config, "queue-limit", cmd_gegl_queue_limit, NULL);
-#ifdef GEGL_ENABLE_DEBUG
- const char *env_string;
- env_string = g_getenv ("GEGL_DEBUG"); - if (env_string != NULL)
- gegl_debug_flags =
- g_parse_debug_string (env_string, - gegl_debug_keys, - G_N_ELEMENTS (gegl_debug_keys)); - env_string = NULL;
-#endif /* GEGL_ENABLE_DEBUG */
time = gegl_ticks ();
