Raw cppcheck full report
Raw cppcheck full report Julien Nabet 05 Sep 19:37
  Raw cppcheck full report Mukund Sivaraman 06 Sep 02:04
Julien Nabet
2012-09-05 19:37:10 UTC (over 12 years ago)
I runned cppcheck, here's some reports which may interest you:
[plug-ins/common/file-pdf-save.c:1264] -> [plug-ins/common/file-pdf-save.c:1260]: (style) Found duplicate branches for if and else.
[plug-ins/common/warp.c:1365] -> [plug-ins/common/warp.c:1362]: (style) Found duplicate branches for if and else. [plug-ins/gfig/gfig-preview.c:235] -> [plug-ins/gfig/gfig-preview.c:231]: (style) Found duplicate branches for if and else.
[plug-ins/common/file-raw.c:730]: (error) Used file that is not opened. [plug-ins/common/file-raw.c:732]: (error) Used file that is not opened.
[plug-ins/common/value-propagate.c:395] -> [plug-ins/common/value-propagate.c:395]: (style) Same expression on both sides of '||'.
[plug-ins/file-sgi/sgi-lib.c:379]: (error) Read and write operations without a call to a positioning function (fseek, fsetpos or rewind) or fflush in between result in undefined behaviour.
In brief, my 2 cents
Julien
Mukund Sivaraman
2012-09-06 02:04:17 UTC (over 12 years ago)
Hi Julien
These have been fixed ^.
I don't think these two reports are correct ^.
This has been fixed ^.
This has not been fixed as it needs a more thorough check ^.
I appreciate that you have run this. Would you spend some time integrating it with our build system so that we can run `make cppcheck' or so and get these reports, if cppcheck is found on the development machine at configure time?
Kind regards,
Mukund
