Building gimp for Mac OS X Lion using Homebrew
Building gimp for Mac OS X Lion using Homebrew | Sanket Khidkikar | 03 Sep 17:43 |
I am trying to build using Homebrew on Mac OS X Lion (instead of MacPorts)
I have installed the required dependencies as per INSTALL, and am following
the directions at
http://www.chromecode.com/2009/12/best-way-to-keep-up-with-gimp-from-git_26.html
Build log below:
---- start of build log --- $ ./autogen.sh --prefix=$PREFIX --disable-gtk-doc
I am testing that you have the tools required to build the GNU Image Manipulation Program from git. This test is not foolproof, so if anything goes wrong, see the file HACKING for more information...
-n checking for libtool >= 1.5 ...
Major version might be too new (2.4.2)
skipping test for gtkdocize
-n checking for autoconf >= 2.54 ...
yes (version 2.69)
-n checking for automake >= 1.10.0 ...
yes (version 1.12.3)
-n checking for intltool >= 0.40.1 ...
yes (version 0.50.2)
-n checking for xsltproc ...
yes
I am going to run ./configure with the following arguments:
--prefix=/Users/sanket/Documents/gimp-git --disable-gtk-doc
glibtoolize: putting auxiliary files in `.'.
glibtoolize: linking file `./ltmain.sh'
glibtoolize: putting macros in AC_CONFIG_MACRO_DIR, `m4macros'.
glibtoolize: linking file `m4macros/libtool.m4'
glibtoolize: linking file `m4macros/ltoptions.m4'
glibtoolize: linking file `m4macros/ltsugar.m4'
glibtoolize: linking file `m4macros/ltversion.m4'
glibtoolize: linking file `m4macros/lt~obsolete.m4'
WARNING: You have disabled gtk-doc.
As a result, you will not be able to generate the API
documentation and 'make dist' will not work.
configure: WARNING: unrecognized options: --disable-gtk-doc
configure: loading site script
/Users/sanket/Documents/gimp-git/share/config.site
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... ./install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking whether gcc and cc understand -c and -o together... yes
checking build system type... x86_64-apple-darwin11.4.0
checking host system type... x86_64-apple-darwin11.4.0
checking how to print strings... printf
checking for a sed that does not truncate output... /usr/bin/sed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc...
/usr/llvm-gcc-4.2/libexec/gcc/i686-apple-darwin11/4.2.1/ld
checking if the linker
(/usr/llvm-gcc-4.2/libexec/gcc/i686-apple-darwin11/4.2.1/ld) is GNU ld... no
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm
checking the name lister (/usr/bin/nm) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 196608
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-apple-darwin11.4.0 file names to
x86_64-apple-darwin11.4.0 format... func_convert_file_noop
checking how to convert x86_64-apple-darwin11.4.0 file names to toolchain
checking for /usr/llvm-gcc-4.2/libexec/gcc/i686-apple-darwin11/4.2.1/ld
option to reload object files... -r
checking for objdump... no
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... no
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm output from gcc object... ok
checking for sysroot... no
checking for mt... no
checking if : is a manifest tool... no
checking for dsymutil... dsymutil
checking for nmedit... nmedit
checking for lipo... lipo
checking for otool... otool
checking for otool64... no
checking for -single_module linker flag... yes
checking for -exported_symbols_list linker flag... yes
checking for -force_load linker flag... yes
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fno-common -DPIC
checking if gcc PIC flag -fno-common -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker
(/usr/llvm-gcc-4.2/libexec/gcc/i686-apple-darwin11/4.2.1/ld) supports
shared libraries... yes
checking dynamic linker characteristics... darwin11.4.0 dyld
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking whether to enable maintainer-specific portions of Makefiles... yes
checking for pkg-config... /usr/local/bin/pkg-config
checking pkg-config is at least version 0.16... yes
checking for target architecture... x86_64-apple-darwin11.4.0
checking for some Win32 platform... no
checking for native Win32... no
checking whether make sets $(MAKE)... (cached) yes
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking whether to turn on debugging... no
checking whether to turn on profiling... no
checking whether gcc understands -Wdeclaration-after-statement... yes
checking whether gcc understands -Wmissing-prototypes... yes
checking whether gcc understands -Werror=missing-prototypes... yes
checking whether gcc understands -Wstrict-prototypes... yes
checking whether gcc understands -Wmissing-declarations... yes
checking whether gcc understands -Winit-self... yes
checking whether gcc understands -Wpointer-arith... yes
checking whether gcc understands -Wold-style-definition... yes
checking whether gcc understands -Wmissing-format-attribute... yes
checking whether gcc understands -Wformat-security... yes
checking whether gcc understands -Wformat-non-literal... no
checking whether gcc understands -fno-common... yes
checking whether gcc understands -fdiagnostics-show-option... yes
checking whether gcc understands --omg-optimized... no
checking whether gcc understands --disable-instructions... no
checking for ANSI C header files... (cached) yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking whether time.h and sys/time.h may both be included... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/times.h usability... yes
checking sys/times.h presence... yes
checking for sys/times.h... yes
checking for sys/wait.h... (cached) yes
checking for unistd.h... (cached) yes
checking for pid_t... yes
checking for vprintf... yes
checking for _doprnt... no
checking for size_t... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for fsync... yes
checking for difftime... yes
checking for mmap... yes
checking whether binary relocation support should be enabled... no
checking for _NL_MEASUREMENT_MEASUREMENT... no
checking whether NLS is requested... yes
checking for intltool >= 0.40.1... 0.50.2 found
checking for intltool-update... /usr/local/bin/intltool-update
checking for intltool-merge... /usr/local/bin/intltool-merge
checking for intltool-extract... /usr/local/bin/intltool-extract
checking for xgettext... no
checking for msgmerge... no
checking for msgfmt... no
checking for gmsgfmt... no
configure: error: GNU gettext tools not found; required for intltool
Configure failed or did not finish!
--------- End of build log ---
$ brew install gettext
Error: gettext-0.18.1.1 already installed
I have exported the following to make sure the system gets the right
version of gettext with no avail:
export LDFLAGS="-L/usr/local/opt/gettext/lib:\$LDFLAGS"
export CPPFLAGS="-I/usr/local/opt/gettext/include:\$CPPFLAGS"
Any suggestions are much appreciated.
Regards, Sanket
