Problem in GIMP Portable 2.8.0 from portableapps.com
Problem in GIMP Portable 2.8.0 from portableapps.com Guiu Rocafort 18 Jul 10:30
  Problem in GIMP Portable 2.8.0 from portableapps.com SorinN 18 Jul 10:53
   gimp 2.8 prohibitively slow Michael Schumacher 18 Jul 15:35
Problem in GIMP Portable 2.8.0 from portableapps.com Michael Schumacher 18 Jul 15:37
  Problem in GIMP Portable 2.8.0 from portableapps.com SorinN 18 Jul 17:26
   Problem in GIMP Portable 2.8.0 from portableapps.com Guiu Rocafort 18 Jul 22:31
Guiu Rocafort
2012-07-18 10:30:20 UTC (almost 13 years ago)
Hello Gimp !
I've found a problem while using GIMP Portable 2.8.0 for windows downloaded from portableapps.com
The problem is that gimp shows 1.3GB as the size of all images. I've noticed this wrong behavior when clicking preview when I export an image. It also happens in the open file dialog ( only in the preview column ). In the open dialog gimp is not showing preview but I guess that the wrong size is causing that because GIMP thinks the file is too big to make a preview.
A little summary: *GIMP Version:* 2.8.0 Portable
*Repeatable:* Always ( tested on 2 different computers ) *OS:* Windows
*Problem:* GIMP shows all files size as 1.3GB *Steps:*
1. Open GIMP
2. Go to Open file dialog
3. In the folder navigation column it shows the real size of the image, in the preview column it shows 1.3GB
1. Open GIMP 2. Create an empty image.
3. Export in jpg
4. Check "preview in image window"
5. Image size estimation is 1.3GB
I've noticed more problems, but there are not as clear as this one and I'm going to take a little time to identify exactly in what conditions they happens. I hope that report is concise enough :)
Greetings Guiu Rocafort
SorinN
2012-07-18 10:53:44 UTC (almost 13 years ago)
Guiu,
go to partha.com and download the right executable.
The one you downloaded is the first compilation of 2.8 (which contain the bug). Partha build is patched against this bug - so look at partha.com for GIMP 2.8.1
2012/7/18 Guiu Rocafort :
Hello Gimp !
A little summary: GIMP Version: 2.8.0 Portable
Repeatable: Always ( tested on 2 different computers ) OS: Windows
Problem: GIMP shows all files size as 1.3GB Steps:
1. Open GIMP
3. Export in jpg
Please avoid sending me Word or PowerPoint attachments. See http://www.gnu.org/philosophy/no-word-attachments.html
gimp-developer-list@gnome.org
2012-07-18 15:35:05 UTC (almost 13 years ago)
Von: Guiu Rocafort
I'm actually very novice yet and my knowledge on GIMP internals is pretty limited. So, those more expert developers: What do you think ? Would it be difficult to compile GIMP with gprof ? Would it be really useful for improving GIMP performance ?
The first steps should be a research in the mailing list archives and in Bugzilla to identify and verify known causes of performance problems:
https://mail.gnome.org/archives/gimp-developer-list/
https://bugzilla.gnome.org/browse.cgi?product=GIMP
Regards, Michael
2012-07-18 15:37:10 UTC (almost 13 years ago)
Von: SorinN
The bug report is
https://bugzilla.gnome.org/show_bug.cgi?id=669818
The changes to prevent it are described in https://bugzilla.gnome.org/show_bug.cgi?id=669818#c28 ff. but there's no verification whether this is considered a fix or a workaround.
HTH, Michael
SorinN
2012-07-18 17:26:56 UTC (almost 13 years ago)
True, is not a GIMP bug is a GTK bug but Partha compilation ( with 2.8.1 which is not an official number probably ) solve that problem
and sometime users just need something to work..
I've tested the executable under WIndows 7 and I can confirm that the problem described by the Guiu is gone.
2012/7/18 Michael Schumacher :
Von: SorinN
The bug report is
HTH, Michael
Guiu Rocafort
2012-07-18 22:31:52 UTC (almost 13 years ago)
I have tried the patha version and the size problem is fixed. Maybe it's just the gtk version in which gimp is compiled against ?
Guiu Rocafort
Von: SorinN
the
bug).
The bug report is
HTH,
Nemes Ioan Sorin
